Question about HP DeskJet F4280 All In One Printer InkJet
Hp deskjet f4280. used printer but just installed to my computer. error on the 'copy' box and resume, resize and cartirdge lights are blinking. power light is constant...not blinking. how do i fix it?
Posted by saving4six on
Ben Johnson
    Director Badge:
    Uploaded 100 video answers.
  • HP Master
  • 685 Answers
The following page describes all the different lights on the front of that printer and what to do depending on what lights are blinking.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01365789&cc=us&lc=en&dlc=en&product=3390949
Posted on Aug 14, 2010
Can't instal printer to Desk top. Lost Disk to my HP F4280
Hi
You can download the drivers for your printer from this link---
HP F4280 printer's driver
After opening the link, select your operating system (win xp/vista,etc). After downloading the driver on to your computer, run the setup and install it. After installation is complete restart your computer.
Daniel Scott
Jun 17, 2010 | HP DeskJet F4280 All In One Printer InkJet
I can't reset ink level indicator for HP Deskjet F4280
AFTER REFILL PRINTER STAY IN ERROR CARTRIDGE BLINKING
Dec 30, 2009 | HP Office Equipment & Supplies
My HP F4280 all in one printer cannot print. the three lights keep blinking. I have paper in the feed tray, and ink that came with the printer correctly installed.
Have you used the disc and installed it on your computer as per instructions? If not or if you used a usb cable and plugged it in too soon, or the installation failed to install all programs for the printer and needs to be reinstalled amd set up again properly.
Nov 12, 2009 | HP DeskJet F4280 All In One Printer InkJet
HP Deskjet 54280 won't print
Try cleaning the print heads. You can find more troubleshooting info in the manual:
http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
Jan 06, 2009 | HP DeskJet F4280 All In One Printer InkJet
Attempts to print on HP Deskjet F4280 shut down my programs
Sounds like the drivers are not installing properly. Are you installing through the CD or downloading the drivers from the HP website. Since a lot of the new drivers are no longer supporting XP you will need to download a scrubber utility and delete all of the pre installed drivers and attempt to reinstall through a manual installation of the drivers.
Apr 18, 2017 | HP DeskJet F4280 All In One Printer InkJet
Light flashing printer no print
unplug the (USB or Parallel) cable of the Printer from Printer backside which is connected to the Computer
open the top lid of the printer and check whether the carriage comes to middle or not?
It it moves automatically, then its fine.
Check the cartridges.
click the URL Link giveb below it will open a webpage. If it does not open a webpage then please copy the entire link and paste it in the address bar of the internet browser and click on "GO"
HP Deskjet 800 Series Printers - Fixing Blinking Lights
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09169&cc=us&lc=en&dlc=en&product=59305&dlc=en&lang=en
HP Deskjets - What are the front panel lights and buttons on the 800 series printers?
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09133&cc=us&lc=en&dlc=en&product=59305&dlc=en&lang=en
Check the End of warranty date on both the cartridges.
Deskjet 882c printer does not support reserve mode printing.
Means, even if only cartridge is defective or expired the printer will not print with other cartridge which is fine.
Both the cartridges should in inwarranty and fine.
Shake the cartridges well
With the color and black cartridges touch a clean, slightly damp cloth (squeeze out excess water),
to the printer nozzle area on the print cartridge, to see if you can make the ink flow freely.
Be careful not to touch the nozzle area (with holes on it) on the cartridges.
Wipe the copper-colored electrical contacts with a clean distilled water or clean tap water and then with a dry lint-free cotton cloth
Also using a new swab, clean the electrical contacts inside the printer, in the carriage.
Install both the cartirdges in the printer, disconnect the printer from the computer and try to print a self test and diagnostic page
Running a sample page
Turn the printer on.
Press and hold the RESUME button until the printer starts printing.
Release the RESUME button.
Running a diagnostic test
Press and hold the POWER button.
Press the RESUME button four times.
Release the POWER button.
Nov 20, 2007 | HP DeskJet 882c InkJet Printer
HP DeskJet F4280 All In One Printer InkJet Logo
467 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
