SOURCE: Drain pump
You must locate the water level sensor which triggers the water pump.It must be stuck to on position. To be helped download user manual below. I did not find exactly your model no (this is 40250i ). if i find i ll sent you a new comment.
http://www.nodevice.com/user_manual/aeg/dishwasher/1193650692_favorit_40250i-w_911234542/download.html
SOURCE: anti flood system has been
Copy and paste to your browser.
www.serviceforce.co.uk/pdfs/U27431.pdf
It will download to your computer and these are the instructions.
SOURCE: aeg favorite 645
to check the antiflood, remove the bottom front panel and the bottom tray is exposed. if there is water in the tray, this will actuate the antiflood switch. just mop out the water and the machine will run. turn off from mains when you do this.
however, this will not give a hum. the antiflood switch just turns on the drain pump.
if no water found then get back to me
SOURCE: Anti flood system triggered Favorit 40660 dishwasher
The problem was solved by opening the machine and finding that the bottom "Y" pipe that has 3 inputs is of extremely poor quality and perforates with pin holes allowing a small amount of water to squirt out. This triggers the anti flood and error status lights flash. The outlet pump is activated and machine does not do anything. You need to replace this hose or like I modified it to work from a 32mm Y plastic junction available from most hardware shops. The wire clamps for this was replaced by "jubilee" screw tight clamps.
I worked on a table and also removed the "Brick" placed at the bottom for balance purposes by cutting the back plastic down with a saw. This made the job very easy...
Testimonial: "Thanks, this was the correct answer and solved the problem. "
