Question about Dishwashers
Hi the water softener function does not work as the lights dont go on when I press the 2 buttons together
Posted by justinmlawre on
Sam
  • Dishwashers Master
  • 3,247 Answers
It would be helpful to know the brand name and model no. of your dishwasher before I can provide any solution to your problem.
Posted on Aug 13, 2010
Ry ecently purchased home has a softener. I don't see any model # or serial # on it. My question is how do I know if the unit is functioning ?
Is it plugged in? Is there salt in the brine tank? Do you ever hear it recharge (usually around 2 am). Does the display show any information on it (time of day, etc)?
Now if it "is" working, do you have soft water? When you run the faucet and lather up with soap, does it form lots and lots of soap bubbles?
You can take a sample of tap water to a local softener supply or one of the big box stores and have them test it for you. If you have soft water <1ppm hardness, just keep adding salt. If not, perhaps your existing softener needs cleaning. Don't let a softener salesman bully you into spending $$$$ if it isn't working. (Most softeners can be fixed with simple maintenance.)
Apr 29, 2016 | Water Dispensing & Filtration
How do I reset the time?
Very common with this type of unit. The switches are prone to corrosion and failure. You can buy a new timer from Sears (~$150) or off Ebay (~$100), or use a simple, no tools procedure, I use on my Sears softener.
-Unplug the softener.
-Carefully remove the top cover from the softener (usually 2 tabs in front and 2 in back).
-remove the timer panel (mine is held on by 2 tabs, one on each side).
-unplug the wiring to the timer.
-remove the timer (mine is held in place by a little plastic hook at each corner, remove one side and first and then the other.
-with the timer out, you can see the switches. while pressing on one of the switches, move your finger in a circular pattern (this rubs the contacts together on the inside of the switch, allowing the contact material to "grind" through the corrosion). Do this with all the switches.
-to reinstall, reverse the processes.
Jan 05, 2016 | Kenmore Elite Hybrid Water Softener Gray...
Is it any user manual available in the web? I could not find any :)
i dont think you can but you can use the instructions below to operate you washing machine
Washing machines may have different technology, but ultimately have the same features and purposes. They all require the proper settings, soap, water and clothes to wash. Yet, there are some things you should know to properly use a washing machine. Follow these steps for success in doing your laundry.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); });
Instructions
  1. Read thoroughly your washing machine owner's manual. These instructions are designed for your particular washing machine. If you don't have an owner's manual, read the button control labels on your washing machine to get an idea of what they do.
  2. Sort your clothes. You should wash white or light-colored clothes together and dark-colored clothes together. Clothes should be further sorted according to their material. Heavy fabrics should be washed together and light fabrics should be washed together.
  3. Add detergent to your washing machine. Follow the instructions on the detergent box. The detergent should go on the bottom of the washing machine unless your washing machine instruction manual specifies otherwise.
  4. Use the special bleach or fabric softener dispensers for your particular washing machine, if you are adding bleach or fabric softener. Otherwise, follow the instructions on the bleach and fabric softener packaging to find out how much and when you should add them to the washing machine.
  5. Load your clothes loosely into the washing machine. Load the laundry as high as your owner's manual specifies or to the top row of holes in the tub.
  6. Close the lid and set the controls of your washing machine according to what you are washing. Use hot water for only white cottons. Use warm or cold water for colored fabrics. Set the other controls according to the weight and durability of your clothing.
  7. Turn on your washing machine. Allow it to work through all of the cycles and turn itself off before you unload the washed laundry.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Tips & Warnings
  • If you're going on vacation or not going to be using your washing machine for awhile, turn off the water faucets to your machine. It will relieve pressure on hoses and valves and minimize any leakage, should it occur.
  • Do not leave coins, nails, screws or anything else in the pockets of your clothes when putting them in the washing machine. They could easily cause damage or even puncture a hole in the drum.
  • Do not wash items that have been spotted or soaked with combustible substances. They could ignite or explode.
  • If you haven't used your washing machine for at least two weeks, and haven't used any hot water in your household, turn on your hot water faucets. Allow them to run for several minutes to release any built up hydrogen gas in your water heater.
Jan 09, 2011 | Washing Machines
Have Error Code E20 - won't drain. How do I approach?
The diagnostic test is used to check individual component function only. TO START THE TEST: • Turn the Program Knob to the start position, Spin Only. • Press Start/Pause to start the cycle and save it. • Press Cancel to stop the cycle and turn off the LEDs. • Press Cancel again to turn on the LEDs. • Within 5 seconds, press and hold the Options and Start/Pause buttons until LEDs start sequentially chasing, then release buttons. 1. All the LEDs will sequentially light. Pressing a button below a light cluster will light all the LEDs in that cluster at one time to confirm functionality. 2. Turn the program knob (1) click clockwise from the start position. The hot water solenoid will activate and hot water should enter through the detergent compartment. 3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water should enter through the bleach compartment. 4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and cold water should enter through the softener compartment. 5. Turn the program knob (4) clicks from the start position. The door lock solenoid will deactivate and the loading door can be opened.When the door is opened, the drum light should turn on. 6. Turn the program knob (5) clicks from the start position. The washer will fill and tumble. Once tumbling has started, the Boost Heater (if so equipped) will turn on. 7. Turn the program knob (6) clicks from the start position. The drain pump & door lock solenoid will activate and the washer will operate in high spin. 8. Turn the program knob (7) clicks from the start position. The control will signal the last error code. Exiting Diagnostic Mode There are two options for exiting theDiagnosticTestmode and returning the washer to normal operation: a) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord OR b) Turn the program knob clockwise 2 or 3 clicks after the start position. Press Options and Start/Pause buttons together for a few seconds until wash cycle LEDs appear.
Dec 26, 2010 | Frigidaire Affinity ATF7000E Front Load...
I have a message saying my ink absorber is full. What do I need to do?
Hi there Joan,
Try these steps:
1. While the printer is turned OFF, press and hold the Resume/Cancel button and Power button. Wait for the lights to turn green. Now, while holding the buttons together, release first the Resume/Cancel button.
2. Then press the Resume/Cancel button thrice then release the two buttons now.
3. When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times.
4. Press the Power button. The LED lights in green, and the selected function is performed.. When the operation completes, the printer returns to the menu selection mode automatically.
6) Power off then back on and test.
Oct 11, 2010 | Canon PIXMA iP1600 Printer
I want to format my nokia 3500c mobile i dont know how to do it plz help me
Method 1:- Press *#7370#
or...
Method 2:- Press *#7780#
Else....
Method 2:- 1) Switch OFF your mobile. 2) Press CALL Button, press 3 & press * together. 3) Now switch your mobile.
Thanks..!!
Sep 21, 2010 | Audio Players & Recorders
Dishwasher will not start.
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
My Bosch Classixx dishwasher is using all the salt in one wash.Why and how do I resolve?
In order to rinse dishes and glasses satisfactorily, the dishwasher requires soft water, i.e. containing little or no lime, otherwise water stains will be left behind on crockery and glasses, etc. If the tap water exceeds a certain level of hardness, it must be softened, i.e. decalcified, so that it can be used in the dishwasher. his is achieved by adding a special salt to the water softener inside the dishwasher. The water softener, that is the required amount of salt, is set up according to how hard the tap water is.
Setting up the water softener
Determine the level of hardness of your tap water. Your local water company or service agent can help you with this. Identify setting from the following water hardness table.
Press and hold the B programme button, and set the main switch to ON, before releasing the programme button again.
The indicator lamp for the B button flashes, as does the figure in the numerical display. The latter represents the value that was preset in the factory.
To change the setting:
Press the B programme button.
Every time the button is pressed, the figure increases by one. After reaching 7 the display starts at 0 again.
Set the main switch OFF. The new setting is stored in the appliance’s memory.
Approx. 4 litres of water are required for regenerating the water softening system. The overall water consumption per load can therefore be increased by between 0 and a maximum of 4 litres according to the water hardness setting.
Oct 11, 2009 | Dishwashers
Cannon np7161
go to servce mode by just press additional function key than 2& 8 no. key together than again additional function key. than by pressin light and dark button go to clear all option than press (A) in light dark button. now switch off your machine than on.
May 16, 2008 | Office Equipment & Supplies
Sky code for remote
The code for you sky remote is 0125.
4 digit' method
1. Turn on your TV.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the Brand Set code for your brand of TV then press select. The light on the Sky remote control blinks twice.
If the light blinks once only, re check the code for your TV and start again at step 1.
6. Press the on/off button (power-top right button on your Sky remote control).
If your TV switched off, press select . The light on the Sky remote control blinks twice.
If your TV did not switch off, press tv , then press the on/off button. Repeat this (press tv , then on/off) until your TV turns off, then press select.
If the light on your Sky remote control blinks three times, your Sky digibox has checked all the possible settings for the code you used. Check that you have the right 4 digit code and start again at step 1.
7. Press tv guide .
If you see the TV Guide screen, the remote control setup process is complete.
If you did not see the TV Guide,you must now set the TV Guide function as follows:
8. Press tv on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
10. Key in the number of the channel on your TV that you use for watching satellite TV (For scart switching, this may be one of the other buttons on your remote e.g. help, i or a colour button).
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
Feb 13, 2008 | Televison & Video
Dishwashers Logo
21 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
