Refrigerators Logo
Posted on Aug 13, 2010
Side by side door is hard to open - Whirlpool Refrigerators
Anonymous
Level 1:
  • Contributor 316 Answers
  • Posted on Aug 13, 2010
Anonymous
Contributor
Level 1:
Answers
316
Questions
0
Helped
105971
Points
21
If you mean the initial "tug" when you open the door, there is most likely absolutely nothing wrong with your refrigerator.
that tug you feel is a secure door to frame seal.
My GE dishwasher door is stuck closed
Have you tried wiggling it side to side? The diswasher may not be secured properly and will vibrate while running. If the counter opening is relatively small it can be hard to open the door if the dishwasher is off center.
1helpful
My 2009 altima s driver's side door wont open from inside or outside thought door was frozen shut so pulled handle hard to try and open now cant open door
You will need to take inside door panel loose which is a little hard with door shut but it can be done and probably replace door Handel if the Handel it's self is not broke it's most likely just a little plastic clip that holds the rod to the lock
I open side door window for removing hard disk and removed hard disk then after closed the door properly but sounding alarm from server so what can i do
It seems to be that side door is not properly closed. Please reopen side door close it again. If it still not work, let's clean up dust from sensor and then try again. Also, please check whether hard drives are properly connected or not.
Please let me know if it still does not work.
Regards,
Kaushik Patel
Door hard to open and close
If you are lucky, you can adjust at the hinge
99 suburban rear door left side problem
Are the door hinges OK. The doors are heavy and often the bushings wear out making the door hard to open.
Refrigerator door doesn't close and seal. Nothing is blocking it.
make sure big compartment door on frige side is completely closing and not holding door open
Dodge caravan sliding door hard to open/close by hand
i'd suggest you just grease the channel top and bottom where the arm slides to hold the door as it's sliding open or closed
I can't get my 1996 Maximas drivers side door to open. It's like it's locked
hi it sounds like either the lock broke or the rods in side of your door have fallen off.you will have to remove the door panel off with the door closed to manualy move the lever in door to get open.it is verry hard with door closed to get door pannel off
Referator doors are hard to open
When you shut the door there is a vacuum occuring and causing the doors to be hard to open. Take someting like a popcicle stick, break it in half and put them together, one on the other and tape it to the gasket at the bottom of the ref side door. This will make a vacuum break and should make the doors easier to open. Also, make sure your gaskets are clean, no sticky stuff on them or the frame.
1helpful
SIDE BY SIDE FRIDGE DOORS VERY HARD TO OPEN
its because the door seals are new and are working correctly. The pressure difference between the warm outside and the cold inside cause a sort of vaccum and so makes it hard to open. It is usually only after the door has been closed a while that it will be hard to open. put your finger around the edge of the door and shift the seal slightly, this will release the vaccum and let the door open normally. It will get better after a few weeks. I have had 2 whirlpools also and this has been the same on both of mine.
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
