Turn off the machine, > Open the front cover > remove the drum, cartridges, > and check if you can see the jammed paper or not, if so pull it out slowly. If you can't see the paper, close the front cover > Pull out the Tray completely > and once again check if you can see it or not, if so pull it out. Still it's not there? then install the tray and open the back door > pull the tab to open the fuser unit and pull out the paper, you can also pull out the fuser unit.
You can also refer to this tutorial from Brother Solution center..how to clear paper jam
Good luck.
Thanks for using FixYa.
I had already removed a paper I saw when I removed the tray. Error light stayed on. But, when I did as you said, to open back door, I found another paper in there, also, that I couldn't see from the front tray area. It works great, again! Thanks!!!
You are welcome, I also glad that it helped you.
