SOURCE: i dropped my laptop
any lights on the front display? (Also check the light on power adapter)
SOURCE: Gateway M-6862 laptop will not turn on; battery light flashing re
Seems to be a problem of not enough power.
First check the voltage output of the charger(adapter) and match it with its specs.
Also try to reset the hardware using the following steps:
1 Disconnect battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Reconnect battery and charger and try to start by pressing the power button.
SOURCE: Powering On Issues
it is the processor i took it out and it booted when i put it back it flashed for a sec then dies the processor is around $150 i don't know if it's worth it or not since the motherboard is $199
SOURCE: I have a gateway ms2273 laptop and it wont turn
You can try switching off the comp. then remove the battery at the back of the laptop then wait for a few seconds before putting it back.
