Question about Paragon 4001-00 24-hr Timer Control 120v Ac Cd101
How do i wire a Paragon 4001-00 timer? - Paragon 4001-00 24-hr Timer Control 120v Ac Cd101
Posted by steveoramma1 on
Anonymous
Link below has wiring diagrams for 4001-00 timers:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
Manual with wiring diagram:
http://waterheatertimer.org/pdf/Paragon-4000-24hr-7000-7day.pdf
4001-00 is wiring diagram #1
There are 3 terminals 1 2 3
Black Hot wire from circuit breaker goes to terminal 1
Black wire to Load (light, fan, motor) goes to terminal 2
Whites wires connect to terminal 3
Posted on Feb 10, 2011
3 Related Answers
Anonymous
  • 52 Answers
SOURCE: Have a Paragon 4001-00 timer that is not turning
Go to electricalexpeditors.com for replacement parts.
Posted on Dec 30, 2009
Anonymous
  • 52 Answers
SOURCE: Can not shut entire timer off.
check for digrams at uniline.com
Posted on Feb 26, 2010
Jim Moody
  • 9 Answers
SOURCE: I need a set of
http://www.patriot-supply.com/products/showitem.cfm/55426
IN STOCK AT PATRIOT SUPPLY!
Posted on Nov 23, 2011
Can you show me paragon timer 4003-0 the wiring
1) Copy following links:
http://waterheatertimer.org/images/Paragon-4000-series-wiring.jpg
2) 4003-0 is 120Volt timer so clock voltage is 120V
Timer can control 120V or 240V loads
Use diagram 3
3) Paragon is no longer making this timer or parts for timer.
If you purchased timer from ebay, then assume motor is bad or X2772 trippers are worn out.
Always buy new timers. Buy Intermatic and parts are easily available.
4) Replacement timer is Intermatic T101
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 16, 2013 | Paragon Hardware & Accessories
The clock on my paragon 4004-71m is not working
1) Clock motor has gone bad, but replacement clock motors are no longer made.
Copy following link for Paragon resources:
2) Paragon is not making parts or replacement motors.
4007-41 is 240Volt timer, replace timer with Intermatic T104
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
3) Crossover wiring from Paragon 4004-71 to Intermatic T104:
Paragon 1 to Intermatic 1
Paragon 2 to Intermatic 2
Paragon 3 to Intermatic 4
Paragon 4 to Intermatic 3
Intermatic terminal A is generally not used for 240Volt
4) Add a comment if needed
Jan 17, 2013 | Paragon Hardware & Accessories
Timer not working on 4000 series, think its 4014 single pole single switch for pool pump. pump turns on when manually turn switch on but timer does not move. I feel the normal resistance and can move the...
1) If circuit breaker is not tripped or shorted, then timer clock motor has probably gone bad.
2) Some places still sell paragon timers, depending on model number.
But model number given is for 240Volt timer.
3) The clock motor is not available that I can find.
Paragon is no longer making the 4000 series timers or parts
4) Model number given does not match wiring terminals shown in manual.
4014 is DPST 240Volt timer with 4 wiring terminals labeled 1 2 3 4.
http://waterheatertimer.org/pdf/Paragon-4000-series.pdf
5) Paragon 4000 series timer with terminals 1 2 3 is 120Volt timer.
6) Replace 120Volt timer with Intermatic T101 indoor timer or T101R outdoor timer.
Crossover wiring:
Paragon terminal 1 goes to Intermatic terminal 1
Paragon terminal 2 goes to Intermatic terminal 2
Paragon terminals 3 goes to Intermatic terminal A
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
7) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 29, 2011 | Paragon 4001-00 24-hr Timer Control 120v...
Need a wiring digram for a pargon5x455 defroist timer
5x455 is WW Grainger number for 240Volt time initiated - time terminated Paragon 8045-20 timer.
Open following links to identify timer and download wiring diagram:
http://www.grainger.com/Grainger/PARAGON-Time-InitiatedTime-Terminated-Defrost-5X454?Pid=search
http://waterheatertimer.org/Paragon-timers-and-manuals.html#8045
Aug 21, 2011 | Paragon 8145-20 Defrost Timer
I need a set of trippers for a Paragon timer Model number 4001-00. Where can I get them. Thank you. My name is Jim Vivone
Google search for X2772 tripper and some places may still have them.
Paragon is no longer making timers and parts except defrost timers.
Paragon 4001-00 120Volt timer uses X2772 tripper:
Paragon 4001-00 crossover to Intermatic is T101 120Volt timer.
Crossover wiring:
Paragon 4001-00 has terminals 1 2 3
T101 has terminals A 1 2
Paragon terminal 1 connects to Intermatic terminal 1
Paragon terminal 2 connects to Intermatic terminal 2
Paragon terminal 3 connects to Intermatic terminal A
Aug 03, 2011 | Hardware & Accessories
I need trippers for parogon elect timer model # 4004-20
1) Paragon is no longer making timers or parts except defrost timers.
4004-20 240V 24-hour mechanical timer is not a defrost timer.
2) paragon 4000 series uses X2772 tripper.
3) Some sites still show the X2772 tripper.
Some sellers are seriously overcharging for the tripper.
4) If you want to buy new timer: Intermatic cross-reference guide shows T-104 240V 24 hour is correct replacement timer
http://www.intermatic.com/customer%20service/competitive%20cross%20reference.aspx
5) Amazon sells new T104 for 50$ which is cheaper than some folks are selling the paragon tripper:
http://www.amazon.com/Intermatic-T104-208-277-Volt-Mechanical-Switch/dp/tags-on-product/B000BQOX88
6) Change-over wiring from Paragon 4004-20 to T-104:
Hot wires from breakers. Paragon terminals 1 and 4. Intermatic terminals 1 and 3
Load wires. Paragon terminals 2 and 3. Intermatic terminals 2 and 4.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Feb 08, 2011 | Hardware & Accessories
Have a paragon amf 4004-71 timer it runs constantly
Paragon 4004-71 is 240Volt timer
http://waterheatertimer.org/Paragon-timers-and-manuals.html#Paragon4000
1) If your trippers are worn down, the timer will not turn on and off
Google search for X2772 trippers.
2) If your timer dial is not rotating, then timer clock motor is bad.
3) According to e-mail I received from Paragon Nov 2010, Paragon is no longer making timers and parts, except for their line of defrost timers.
4004-71 is not a defrost timer, so it is no longer being made according to Paragon representative.
4) To change timer brands: Intermatic cross reference shows Paragon 4004-71 can be replaced with Intermatic T-104 timer.
Intermatic cross reference link:
Lowes and Grainger and many other outlet sell T-104 240V timer.
5) How to wire T-104
Dec 15, 2010 | Woods Outdoor Photoelectric 24 Hour...
I have a model 7005 outdoor timer ,brand new but no instructions to proceed with settings .Can you help me?
72d1511.jpgParagon 7000
Paragon 7005 is a heavy duty 7-day mechanical timer that can handle 4 loads. It is DPST. One of two wiring diagrams applies to this timer:
1d6e8ec.jpgThe question is the the timer clock motor is 120V or 240V?
36b7dc9.jpgParagon EC 7000 is a 7-day digital timer with 16 set points per week
Manual for EC7000
http://waterheatertimer.org/pdf/Paragon-EC7000-wire.pdf
Please re-post your questions as you start sorting out which timer you have.
Paragon is improving their site so there is less confusion over model numbers and functions. but information about the 7000 are still sketchy.
Oct 15, 2010 | Paragon Hardware & Accessories
I have a paragon timer model 4004-20 and do not have a wiring digram for it . can you help
I don't find the Paragon 4004-20 listed in manual.
4004-71 is shown, and uses wiring diagram 3
4004-71B, M, S use wiring diagram 4
4004-06 uses wiring diagram 7
Your timer sounds like a 240V DPST
Manual shows wiring diagrams, depending on how many screw terminals and loads you have, and voltage of clock motor and voltage of load.
Aug 21, 2010 | Paragon REPLACMENT MECHANISM 110V SPST -...
HOw to disable the paragon 4001
4001 series timer is Paragon 120V mechanical timer.
1) To disable the timer, turn off circuit breaker and take wires off of the terminals. Put wire nut over each wire, and circuit will no longer operate.
2) If you want the circuit to operate without timer, then take wires off terminals. Twist black wires together and cover with wire nut. Twist white wires together and cover with wire nut.
3) Buy Intermatic T-101 timer to replace Paragon 4001 timer
Sep 13, 2009 | Paragon 4001-00 24-hr Timer Control 120v...
Paragon 4001-00 24-hr Timer Control 120v Ac Cd101 Logo
3,001 people viewed this question
Top Paragon Hardware & Accessories Experts
Gene Haynes
jdthefixer
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
