Question about Nokia 6300 Cellular Phone
My nokia 6300 handset was bought 1year bck..from ystrdy the cell gets switchdoff automatically and its not getn on . i try to switch on the cell but just nokia greeting msg comes and the cell again gets switchdoff. what is the xact problem with the cell???
Posted by thakur_aarti on
Anonymous
  • 370 Answers
This seems to be a software problem,this can often be solved by performing a software update. Software may perform incorrectly for many reasons without there being a fault in the phone. Some problems may be fixed by re-updating your current software, while others may require installing a new software version.
To keep your phone performing at its best, it's a good idea to perform a software update regularly. You might not always notice what an update has done, but it can prevent future problems.
To update or reinstall the software please go to nearest authorized NOKIA CARE centre and they will update or reinstall the software as required.
Note: Reinstalling the software will delete all the content in your phone like contacts, calendar entry etc.
Thank You
Posted on Aug 13, 2010
Hi i have a nokia 6300, when i try to download games or set up email, my handset says there is not enough memory even though i have a 2gig memory card, i need to find out how to get my handset to go...
The games or the apps you download will be added to games automatically, onething you can do is move the pre download games and apps to the memory card, i mean you should move the games and apps to the memory card before making new downloads...rate my answer
Sep 23, 2011 | Nokia 6300 Cellular Phone
My 6300 wont switch on. {battery is charged} iv used a replacement none nokia battery,it was working ok. it wont charge either
Hii
Firstly never try to use local battery because they are not good enough and damages handset .
check your battery in other mobile if its works in other mobile then your handset need to be FLASHING ie. updation is required.
Update your handset and never use local battery always use nokia brand.
Thanks to help you
Aug 20, 2011 | Nokia 6300 Cellular Phone
Need a code to open a nokia 6300
The Nokia 6300 is very simple to unlock. By using our unlocking method, your Nokia 6300 can be unrestricted as quickly as entering a short code into your phone You will achieve a the ability to use the SIM card of your choice. Unlocking your Nokia 6300 enables you to use the SIM card of your choice which permits you to take advantage of using whatever network that is the most favorable for rates. As with all services of Unlocking.com we guarantee 100% that your Nokia 6300 will be unlocked. We have a money back guarantee if we don't successfully unlock your cell phone. We also promise your cell phone cannot be damaged during the unlocking process.
When traveling out of country, your handset will be able to accommodate SIM cards bought locally making it possible to use local networks. An unlocked Nokia 6300 will be a more desirable item for resale. It's simple to unlock a Nokia 6300 phone using an unlock code purchased from us.
Jan 21, 2011 | Nokia 6300 Cellular Phone
Ive bought a nokia 6300 and i need the unlocking code so i can put my o2 sim card in to the orange handset? where can i get the code
you can unlock your phone here http://www.theunlockarena.com/nokia-6300/rs13wp9/
They will provide the code when you enter your imei number,you just need to select your phone model and network provider
Oct 08, 2010 | Nokia 6300 Cell Phone
My nokia 6300 does not start properly. When I switch it on it starts showing me the display sign but then switches itsel*** automatically.
try removing battery for ten mins then try again the try removing memo card if it remains you have to take it to a nokia care centre
May 20, 2010 | Nokia 6300 Cellular Phone
My nokia 6300 handset asking for security code
this master code can fix all code related problem in your mobile 6626060166
try it
rate it
Jan 09, 2010 | Nokia 6300 Cellular Phone
How to unlock my keyguard security code for nokia 6300 handsets?
lost my security keyguard for nokia handsets,y IEMI NO IS 359809019176529 CAN U POST MY mastercode my email id is [email protected]
Oct 18, 2008 | Nokia 1100
The microphone is not working
the microphone opening is on the bottom left as viewed from the front, when i had this problem it turned out that this opening had some crud in it and simply needed removing. steve
Feb 17, 2008 | Nokia 6300 Cellular Phone
Nokia 6300 Cellular Phone Logo
73 people viewed this question
Top Nokia Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Zaid Anarwala
Zaid Anarwala
