Question about Casio FX-300MS Calculator
How to use graphing calculator? - Casio FX-300MS Calculator
Posted by sofronionino on
k24674
  • Casio Master
  • 8,091 Answers
The casio FX-300Ms calculator cannot do graphs. To tell you how to use a graphing calculator TO DRAW GRAPHS we need to know the exact brand and model number of the calculator.
  1. Most graphing calculators basically function the same way.
  2. You select the graph type (function, polar,parametric, sequence, 3D, wire mesh, slope field, etc.)
  3. You enter the algebraic form of the function you want to draw.
  4. You press a button or menu to GRAPH
  5. The graph is drawn.
  6. If you want to see a particular part of the graph, you use a ZOOM function, or you enter values for the WINDOW dimensions.
  7. Most graphing calculators have a TRACE function that allow you to follow the curve you have drawn to read off values of coordinate points.
  8. You can also use the calculator to find zeros roots) of functions, calculate derivatives at some chosen points or calculate the area "under the curve", find the minimum and maximum of a function.
In addition to its graphing capabilities, a graphing calculator can be used as a scientific calculator. Sometimes it can also do statistical and financial calculations, matrices, list manipulations, operations on complex numbers, text editing,, creating programs etc.
Posted on Aug 13, 2010
How do I graph x<-3 on the calculator?
First you must use a graphing calculator.
Most graphing calculators graph functions, i.e. relations of the form y=f(x).
Some graphing calculators are able to graph equations (not necessarily functions). On one of these calculators your draw the vertical line x=-3, then you shade to the left of the point x=-3. That gives you the real line from infinity up to but not including x=-3.
Generally, people do not need calculators to find the solutions to inequalities in just one variable.
Jan 06, 2016 | Office Equipment & Supplies
Graphing ellipse
This is not a graphing calculator. Besides, most graphing calculators are able to graph functions, and conics are not functions. You need a utility that graphs conics. The Casio FX-9750G and others have a conics utility. On the TI83/84 Plus you can download an application that draws them.
Oct 30, 2013 | Casio FX-115ES Scientific Calculator
How to graph polar equations
Your calculator does not have graphing capabilities. On a graphing calculator you would first select the graph type 1. function y= f(x), 2. parametric x=x(t), y=y(t), 3.polar r=function(theta).
Mar 03, 2013 | Casio FX-115ES Scientific Calculator
How do i graph three equations on my calculator
Your calculator cannot, natively, perform 3D graphing.
Jan 28, 2013 | Texas Instruments TI-84 Plus Calculator
Can i plot graphs using fx 115 es?
The fx-115ES is not a graphics calculator so it will not display graphs on its screen. You can use it to make graphs by calculating the points and plotting them on graph paper.
Mar 12, 2011 | Casio FX-115ES Scientific Calculator
We already have this calculator and need to know if it is considered a graphing calculator. Thank you, RH
While it may have many of the same functions as a graphing calculator. It cannot produce a graph on the screen. This is required for most classes. It is not considered a graphing calculator, and you will most likely have to buy a new one.
Aug 23, 2010 | Casio FX-250HC Calculator
Math 116 - Algebra
this calculator is not a graphing calculator; it won't be able to actually show you the graph but it can give you graphing points.
Sep 04, 2008 | Casio FX-115ES Scientific Calculator
Graphing
The first solution will allow you to watch your calculator graph two equations simultaneously rather than finishing one before graphing the next; it won't solve the problem of having the calculator unselect one equation when you select a second. To fix that problem, try the following:
In order to select additional graphs, the Transformation Graphing App will need to be uninstalled from the TI-83 Plus Family and TI-84 Plus Family. Uninstalling the App does not erase it from the calculator, it disables it from interfering with the normal graphing modes. Below are the steps to successfully uninstall the App.
  • Press [APPS] key
  • Select Transfrm from the menu
  • Press 1:Uninstall
The illustration and solution are courtesy of Jesse Phillips, who cites this page from the Texas Instruments support site
- doug garfinkel, Children's Day School
Jan 15, 2008 | Texas Instruments TI-84 Plus Silver...
Casio FX-300MS Calculator Logo
544 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Colin Stickland
Colin Stickland
Marvin
Marvin
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
