Philips 55P8341 55" Rear Projection Television Logo
Posted on Aug 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a philips big screen projection tv modul#55p8341 that turns off after being on for a while. great picture and sound
Willard Broughton
Level 2:
Sergeant:
  • Expert 252 Answers
  • Posted on Aug 13, 2010
Willard Broughton
Expert
Level 2:
Sergeant:
Answers
252
Questions
0
Helped
41633
Points
715
Your horizontal output chip is going bad after it heats up to a certain point it fails and shuts your set down. After a while if not replaced your set will fail to power up at all.
Need the default coloring for the Philips 55P8341 tv
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Tv menu
I am having the same issue! Ugh!
Pillips projection tv
I HAVE A PHILIPS M#55P8341A THERE IS DOUBLE PICTURE ON THE SCREEN IF YOU HAVE ONE PERSON THERE YOU SEE TWO OF THEM ONE IS RED THE OTHER IS GREEN?
Phillips 52" big screen is looking blurry. Can I tune it myself?
my projection tv color is red I have tried ajusting the color but nothing the pic is still to red
Power Problem (Phillips 55P8341 Projection TV)
Same problem... I pulled out the second electronic board going from right to left and see a burned diode at position 3307. I wanted to know if anyone has a schematic of this TV and could tell me the numeric value of the part in position 3307. It would be appreciated it you could let me know.Thanks...
Blinking lights on philips 55P8341
5 volt protection is causing the set to go into protective shutdown. Check for shorted diode 6306. Part#934038020127
or shorted capacitor 2318. or faulty voltage regulator
Cannot adjust colors
sounds like your red tube is getting a short I can post you a web sight and they have used red picture tubes
http://servicemanuals.vstore.ca/
Phillips model# 60p8341
Let me get this straight, you don't have a picture as long as the unit is on, but when you go to turn off a picture flashes? Questions, first how is the picture when it flashes briefly? Is it normal or with colors misaligned? How is the sound? Could be a loose connection or bad capacitor in the video circuit.
No sound no picture
This is a common problem with older Philip Magnavox projection sets. Over time one of the IC chips on the main power board begins to fail. You can find replacment chips and repair instructions on www.magnavoxhelp.com.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
