Question about LG 42PX5D 42 in. Plasma HDTV
Hi, I have a 42" LG SD Plasma TV that is 5 years old (model PX423RVC-TA). A week a go the picture went pink / purple even on the OSD on any input, this was intemittanty. Now the their is no picture, but sound! I have read that this could be the YSUS board?? I have checked the boards and there are no buldging caps etc. With the fault originally being pink/purple to good and then no picture, could this be a capacitor problem or would it be the chip? Thanks Paul
Posted by paul_ande659 on
5 Related Answers
jerryg50
Jerry Greenberg
  • 1691 Answers
SOURCE: LG Plasma Problem
This could be the main drive board failed, or the plasma display backplane has a defect. These types of repairs are generaly fairly expensive.
I would be considering to get an estimate just in case it is simple fault. But, if the repair will cost more than a few hundred dollars, I would strongly suggest a new set. Also, servicing an older set is a gamble in case something else will soon fail.
Jerry G.
Posted on May 15, 2008
john clyde
  • 70 Answers
SOURCE: Philips Plasma 42" - constant purple haze
all philips plasma sets have issues with overheating heatsinks.
any heatsink that burns you upon contact is a recipe for disaster.
using cooling fans on these overheating parts will generally provide
great reliability in the long rung.
Posted on Nov 10, 2008
kenn green
  • 90 Answers
SOURCE: ysus board
the mainboard, controls the audio, Tv Tuners, Vga , HDMI, S- Video inputs.
The Y sus or (Y-Mainboard ) Is used to control the Panel (LCD) Video, it has 2 buffers that contol h/v lines in upper & lower regions.
Posted on Apr 28, 2009
Anonymous
  • 55 Answers
SOURCE: PINK SCREEN ON DAEWOO PLASMA TV
Sounds like your panel might be going out or a faulty video card. This is the first time I have heard of a solid pink screen on a plasma. Usually this happens on LCDs, though they sometimes go white and stay white, which does signal a bad panel. tv needs repair
Posted on May 09, 2009
Cary Leonardt
  • 304 Answers
SOURCE: pink vertical line down my 42 inch digital plasma
I do believe the Panel is bad and needs to be replaced. Check with the manfacture to confirm this.
Posted on Jul 16, 2009
Hi Have this model for about 5 years and picture faded this morning. connected to cable and tested with a DVD input same result...is the TV repairable or do we need to get a new one? thanks
unfortunately plasma TVs have a certain shelf life, the plasma only lasts a few thousand hours, i would'nt competely scrap the TV, put a small ad in the newspaper asking to buy a plasma, same model that has been hit by lightening or power surge with an offer, chances areyou might be able to slavage the screen.
May 03, 2010 | LG 42PC1DA 42 in. Plasma HDTV
My 42 inch plasma has black distorted picture
hi
its cathode ray tube problem or the colour wheel...check that both please.....
thank u,,,,,,
Mar 07, 2009 | LG 42PC3D 42 in. Plasma Television
No picture or sound on LG 42" Plasma
Hi Craig,
Your Tv has a 1 year warranty, you should contact Customer Service as soon as possible. This is the number in the USA 1-800-243-0000
If needed this is the Global Site. www.lge.com/products/category/list/tv.jhtml
Enter your country then click on Support for the Service Number.
If this helps please rate this solution as a FixYa.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Jan 29, 2009 | LG 42LC2D 42 in. LCD HDTV
LG Plasma Problem
Jerry G.
May 09, 2008 | LG 42PX5D 42 in. Plasma HDTV
No picture
Hav 50 inch lg no pic but got sound wtf how do i fix it an there r 5 flashes b4 green light stayes on at the start
Apr 10, 2008 | LG 42LC2D 42 in. LCD HDTV
42 inch LG Plasma TV - Lost picture
Our LG 50" plasma tv screen went black after a popping noise but still had sound, after great diliberations decided to take the back off and have a peek!
We unplugged the tv and tested the fuses (there were three we could see) one had blown, the one on the left as you look at the back of the tv it also has one above it. We wrote the code/seriel number down and took the fuse to the electrical wholesalers Maplin and bought a pack of 10 fuses for £1.29 replaced the fuse in the tv and everything now fine!!!!!!
Hope this might be of use to anyone whose lost the picture after a loud popping/snacking noise but still has sound.
Dec 31, 2007 | LG RU-42PX10 42 in. HD-Ready Plasma...
LG PLASMA TV WITH COLOURED LINES OVER SCREEN
If the Video (Picture/Pix) is gone but you can hear the Audio (sound), then it could mean the YSUS PCB Assembly is gone/kaput/finish. Can replace the PCB, not repair the PCB due to timing circuitry involve. Cost maybe roughly $500 depending where you located. The PCB is located on the left hand side of your TV when you are facing the back (Back open). Might find 3-4 brown flex membrane connecting to the plasma panel. The PCB has a silver or black aluminum heatsink (big) on it.
Good Luck.
Dec 22, 2007 | LG 42PX5D 42 in. Plasma HDTV
ysus pcb that supplies voltage to the panel is faulty
Dec 14, 2007 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
LG 42 PLASMA
check all inputs on tv ,also check if menu on tv is working ,make sure lines arent being produce by another source, cable box etcc..If menu and or OSD are affected .Then there is a good chance you have lightning damaged some where in signal section on tv .
Dec 03, 2007 | LG 42PX5D 42 in. Plasma HDTV
LG 42PX5D 42 in. Plasma HDTV Logo
118 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
