Question about Mitsubishi WS-55511 55" Rear Projection Television
When you turn the tv on it go right back off Mitsubishi WS-55511 55 in. It about (5)yrs old I have try unplugging the tv for about 3 to 5 minute
Posted by dmumford on
SD Tech
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Do this: When you turn it on and the green power light comes on and goes off:
On the front of the set press and hold BOTH the Menu and Input buttons at the same time for at least 5 seconds and then release both.
This model has a self check: The green power light will then blink a two digit error code: most common is 2 blinks, 2 blinks and a pause and repeat the error code at least 5 times.
Let me know what you find and I will tell you what it means.
I hope you get 2,2 as it is the most easy to resolve.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
REGARDS, SD TECH
Posted on Aug 12, 2010
  • 4 more comments
  • br16 Aug 28, 2010
    Hi there - I did the test and it came up with a 2,2. How do I resolve this?
  • Anonymous Sep 02, 2010
    I replaced the 7 capacitors and mine came on and stopped blinking.
  • TBone54 Sep 03, 2010
    brianself73 did you have the 2 blinks, 2 blinks error code as well? the 7 capacitors were the problem?
  • annedc Sep 11, 2010
    i am getting 2 ,1 blinks missing my tv!
  • SD Tech
    SD Tech Sep 11, 2010
    Person with 2,1 error code post a free question attention SD TECH.
    SD TECH
  • jamie_g07 Sep 13, 2010
    so what if the code is 1 blink, 2 blinks...it means no issue detected? well i have an issue.. now not only doesd it turn off, but the screen has lines through it also
Anonymous
    New Friend:
Sony rearbprojection tv. model number kp57h40m tv turns on then turns off after a few seconds
Posted on Aug 30, 2010
One of the lamps on ws- 65809 is not working need to know where to get the part and how to remove it
Can't get the part as the tv is 10 yrs old, have a professional technician do it. not for beginners
Jul 31, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Ws55511 wont turn on just get the flashing green light of death!tv is 9 yrs.old no other problems.what can I do about this problem?
Install the DM repair kit called the WS48511 - WS65511 DM repair kit which is available from www.tvrepairworld.com the kit has the capacitors and the CD with repair instructions.
Jul 30, 2011 | Mitsubishi WS-55511 55" Rear Projection...
I have a WS-48311, lrss then 8 yrs old. When you turn it on the power light comes on and goes out in a few seconds.
Could be just end of bulb life. with it being 8 years old. get a manual for it and look in there what is suposed to happen at the end of the bulb life.
Aug 25, 2010 | Mitsubishi WS-48311 48" Rear Projection...
My Mitsubishi TV is about 12-14 yrs old. The
DLP projection tvs are bulky and have a design flaw in the convergence board the 2 STK convergence ICS alway dies constinely require replacement,if u use about 4 or 5 hours day in and day out.If the old Mitsubishi tv several years since is was repair,u use it alot?If yes,it time to retire it,and buy the refurbish Plama tv.Not,than get the old tv repair.U Know how to solders?Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.U can go to You Tube type in Convergence problems will see a tutoring video in repairing 2 STK Convergence ICS.
Mar 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
I turn on the tv and it shuts off after a couple seconds
if you unlpug your tv and plug back is the green ligth blinks for one minute?
let me know so i csn help you
Jul 29, 2009 | Mitsubishi WS-55807 TV
I have a rear proj 65" about 6 yrs old. 2. problems. Most important right now is that it turn off a few seconds after I turn it on. I hear the electronic click, see the green light by the button...
This is definitely a problem you don't want to tackle at home. TV's are made to kick off when it knows a problem exists. The warped pic is a "convergence IC" issue. That IC needs to be replaced by a tech, either in home or in shop.
May 08, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi projection TV WS - 55413
any flashing LED's when running service mode or convergence signal?
Apr 27, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WT-A42 projection 42" HD1080 series
It sounds like your regulator circuit is defective. Not an expensive repair, maybe $200.or a little more.
Apr 08, 2008 | Mitsubishi WS-65909 65" Rear Projection...
Mitsubishi WS-55311, 4 yrs old, flashing screen on all inputs
First thing to try is to press the reset button on the front of the TV. This forces a system reset.
Feb 03, 2007 | Mitsubishi WS-55311 55" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
413 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
