Question about Refrigerators
How to set a temperture - Refrigerators
Posted by jodycoleman on
Anonymous
    President:
  • 1,099 Answers
By keep your refrigerator or freezer too cold, it unnecessarily wastes electricity. The recommended temperature is 37 to 40 degrees for the fresh food compartment of the refrigerator. The recommended temperature for the freezer compartment is 5 degrees. If you have a separate freezer for long-term food storage, it should kept at 0 to -5 degrees.
The following steps below is how to set the temperature of your refrigerator.
The first thing you must know is that your refrigerator should be set at 37-38 degrees. Anything at 40 or higher and you are risking food born illness (food poisoning) or spoiling your food.
Step 2
Place your magnetic thermometer in the refrigerator.
Step 3
Set your dial on your refrigerator to the second lowest setting. (If your refrigerator is already equipped with a digital thermostat, simply set it for 37 or 38 degrees and do not move on to the next step)
Step 4
After 2 hours, check your thermometer reading. If your reading is 38 degrees, there is no need to go higher and you are ready to put your groceries in. Be sure not to open and close your refrigerator during these two hours or your temperature reading will be incorrect.
If your reading is higher than 38 degrees, move your dial up to the next coldest setting and repeat the steps every two hours until you reach the correct temperature for your refrigerator.
Step 5
Once you have reached the correct refrigeration temperature for your refrigerator, place the magnetic thermometer in the refrigerator permanently and watch for changes.
Typically, your refrigerator temperature will need to be adjusted with the seasons, a higher setting in the summer and a lower setting in the winter.
Hope this helpout and take care.
Posted on Aug 13, 2010
Adjustment temperture on ge side by side model gss25gfxaww
You can't adjust it. You can set a new set point and see if it gets there in 24 hours, otherwise you might have a problem with you fridge.
Jul 25, 2012 | GE GSL25JFPBS Side by Side Refrigerator
High temperture
Have you check the thermostat?
You might want to remove it and install a new one see it still overheats.
May 27, 2008 | 2006 Chevrolet Cobalt
My 2007 Chevy HHR 2.2L, coolant temp sensor is reading that the coolant temp is 20 degrees warmer than the outside temp after sitting for over 12 hours and the operating temp gets to 214 degrees without...
Sure the engine coolant will be warmer than the outside temperture and if the car has been sitting a long time in cold weather and the outside temperture warms up it could be the other way around. The coolant temperture sensers aren't real accurate as they are a relaitive senser beween hot and cold and the numbers reported don't have to be real just the change from hot to cold and the reching of the coolant to the operating temperture. Noe it the senser doesn't read the opertating temperture coprrectly you'll have all kinds of problems. The therostaste will try to set the temperture of the water to it's set temperture and can open or close completly to get 195 degrees F. Many times if it's too cold then the stat is bad and needs to be replaced This shows up in alot of cars first thing after winter and the first onset of cold weather when the daily tempertures vary the most from day to night.
May 06, 2011 | 2007 Chevrolet HHR Special Edition
Hot water temperture will not go over 33 degrees
Check your water heater thermostat on you water heater tank, look for a small removable panel, remove the insulation and then you should expose the thermostat of the water heater
Readjust the thermostat to the desired temperture just be sure not to set to high to cause problems with small children.
Apr 11, 2011 | Home
How do you program this heater
temp setting
1. press the temp/timer button untill the temp icon blinks
2 use up and down arrows to set temp.3 the temperture icon will stop blinking and the current room temperture will appear after desired temp. is set.
4 the heat will turn off shortly after the desiredtemp. is reached and the temp. ndisplay will blink.
5 the heater will turn back on when room temperture drops below the set temp.
timer : auto -off press the temp/time button untill timer icon blinks. the hour display will apear. the auto off icon will also appear.
2. use up and down arrow buttons to set the heater operation time between 1 and 10 hours. this function will activate once the timer icon stops blinking.
3. the heater will automaticly turn off when time runs out.
set temperture first so heater will cycle on and off till shut down time reached
Feb 02, 2011 | Comfort Zone CZ9009 Oil Filled Electric...
The problem is with the heater.
3 words come to Mind. Heater Blend Door
Mar 17, 2009 | 1999 Ford F150 Regular Cab
Siemens RDE20.1 upper temperture setting
Hold the return and + button at the same time for at least three seconds, then adjust the indicated temperature down which tricks the thermostat in heating to a higher temperature before the set point is reached.
Dec 09, 2008 | Siemens Efficient Networks SpeedStream...
TOW FANS AGAINST THE RADIATOR, TOYOTA CAMRY 2001 4 CYL
yes, they are both radiator fan. dependent on the temperture of the outside air and the cooling temperure on control panel. the fan will kick on when the temperture cross over the preset- set on the computer. so, either fan on, no fan, fan is runing when the car is runing or not, is not a porblem.
the porblem occures when the fan stops, and the temperture is over 100 degree outside.
Nov 11, 2008 | Compaq Presario 1626 Cooling Fan Case...
Not turning on
Sounds like you have a bad t-stat. You could take a reading through it when you turn the temp up to see if it is operating.
Apr 03, 2008 | Pitco Frialator SG14 Deep Fryer
Open Questions:
Refrigerators Logo
Top Refrigerators Experts
Dan Webster
Dan Webster
john h
