Wow, big OS problem here.
Windows 7 and Vista both have a serious problem playing games for the previous OS's (XP, ME, 2000, 98/95, 3.1). There are sometimes fixes that you can find on the web (download such and such driver or whatever.) but these only work about 15% of the time. Your best bet to get it to work is to find the .exe file that runs the game itself (right click on the shortcut and click "open file location"). When you find the .exe, right click on that and go to properties, then click the "compatability" tab. At this tab you can set the compatability settings to try and get the game to work. THIS DOES NOT ALWAYS WORK. If it doesn't, then most likely the game is simply too old to work on an OS as recent as windows 7. At that point your best bet is to hunt for a more recent version of the game you want to play (one that is compatable with win7)
Microsoft Windows 98 was an operating system used on a majority of personal computers from 1998 to 2000. Because of this, there are a variety of games available to play on Windows 98, but are incompatible with later versions of Windows. If you have Windows XP or higher, you have access to a "Compatibility Mode" that allows your computer to play those games. Activating compatibility mode is a simple procedure.
Right-click the file that you usually click on when you are trying to start a game.
Select the "Properties" option in the drop-down menu.
Select the "Compatibility" tab, then check the "Windows 98" box.
Select the proper video mode for your game under "Display Settings."
Select the "Apply" button to save your settings, and select "OK."
Double-click on your game's file to begin playing the game.
