46 inch deck with Kohler engine. About a year old. Replaced battery, Since it would not hold charge. Now the oil light is blinking at 51.6 hours. I changed the oil and filter at 25 hours. Manual says then change every 100 hours.
Did the battery change cause this blinking light?
How do I reset it? Should I ignore it? I could not find any reference to this in the manual.
Please help. THANKS.
Dave, grab some gun out or any old carburetor cleaner... remove spark plug, spray a few squirts into the hole then reinstall the plug. Now go to the carburetor, spray some into it as well....
Try starting it , if it starts and runs for a matter of seconds then your carburetor needs to be serviced...and THAT you can do yourself...trust me. If you need help on how to do it, I will send you a link for a you tube video.
Cub Cadet has five models in their new Series 1000 lawn tractors, all
powered by Kohler engines. Cub Cadet models -- as several other lawn
equipment brands -- are manufactured by MTD Products.
The Cub
Cadet LT 1045 has a 20-hp Kohler single-cylinder engine, with an
aluminum block and cast-iron sleeve for longer life. It has a
full-pressure lubrication system with spin-on oil filter for easier
maintenance. This engine is not as powerful or as long lasting as the
Kohler V-Twin OHV, which is available in other models in the line, but
the LT 1045's engine is still solid enough to provide years of mowing.
The hydrostatic (automatic) transmission is a good match with the
engine and provides sufficient grip to cut grass on moderate inclines.
Power is transferred from the engine to the transmission by a heavy-duty
Kevlar belt rather than a more expensive shaft drive. A Kevlar belt
also drives the three cutting blades.
The mowing deck cuts a
swath of grass 46 inches wide at one pass, and is removable for service
and cleaning. Four anti-scalping wheels help keep the deck from scalping
grass on uneven ground. The cutting height is manually adjusted from
1-1/2 to 4 inches. The turning radius is 18 inches, which standard for
lawn tractors. This model is intended for use on 1- to 2-acre lawns
without many turns or small obstacles.
