SOURCE: 3Com OfficeConnect Wireless 11G password
Press reset button on the rear of the unit for 5 secconds, then by connecting your moden in to yor laptop go to the following web page: http://www.3com.com/products/en_US/detail.jsp?tab=support&sku=3CRWE454G72&pathtype=purchase and there you will find the software and manual for your AP (access point) the software will let you setup the device from scratch. the default password is admin. hope this helps.
SOURCE: Dir-655 works with XP and Mac which can connect
Go to 192.168.0.1 and login. Then go for the 'Setup' tab on the top and look for the 'Wireless Settings' tab on the right.
You can now automaticly setup your WLAN connection and afterwards you can go to the 'Manual Wireless Network Setup'. Over there you can change the 802.11 mode.
Go for the last one that uses n,g and b and you will be sure your computer can connect :)
SOURCE: i forgot my admin password for Wirelles Router
if you havnt changed the password to the router then it should either be "PASSWORD" "ADMIN" "ADMINASTRATOR" in the worst case senreio you may have to reset the router.
