Watches Logo
Posted on Aug 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I do not know how to set my daughters digital watch from walmart. It does not have a manual.
  • Anonymous Aug 12, 2010
    What is the make of watch?
Janelle Schoonover
Level 3:
  • Master 842 Answers
  • Posted on Aug 12, 2010
Janelle Schoonover
Master
Level 3:
Answers
842
Questions
Helped
457493
Points
2634
  • Take a look at your watch. While models and brands vary, you'll find a few things in common on almost all of them. First, they'll have different modes of operation. A typical digital watch may have modes for time, stopwatch, date, alarm and timer, to name a few. Look on your watch for a button labeled "mode." Press it several times to see what's available. Typically the watch will display the name of each mode as you push the button repeatedly. When you've found the mode you want to adjust, stop there.
  • Step 2 Look for a button that is labeled "set" or "adjust" on your watch. The location will vary, depending on the brand of watch you own. Press in and hold this button. After a few seconds, the time (or whatever mode) you have selected will begin to flash. In most cases, you'll need to select the item you want to adjust (minutes or hours) by pressing "mode" again. Once the portion you want is flashing, you're ready to adjust it.
  • Step 3 Press a button to advance the parameter (hours or minutes) that you've selected. This button may or may not be labeled. If it isn't labeled, you'll have to experiment with different buttons. Once you've set the first parameter, change to the second by pressing "mode." Follow the same routine to adjust. To exit, you'll typically press the "set" button.
  • Best I can do for you not seeing the watch Good luck
  • Add Your Answer
    Need setting instructions for a MDC74567W watch
    Don, try the attached link or contact Walmart,they may be able to get the instructions for you.
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
    http://www.hawsedc.com/thomas/tiki-index.php?page=Walmart+Advance+watch+instructions
    Timecenter Men Dress Casual Watch
    May 01, 2016 • Watches
    I have an alarm chrono watch from walmart and I can't get it to back to 12-24 hour display
    For most of the cheap Chinese digital watches sold at Walmart you simply scroll through the different numbers while setting the hour part of the time -- 1 to 12 then 13 to 23 to 0 then 1 to 12 AM and 1 to 12 PM then 1 to 12 to 13 etc. When the watch is in 24 hour time (as used by most of the world outside the US and Canada) most will show the letter H instead of A or P.
    For some of these watches, you need to be in Alarm set mode to be able to scroll through all the choices, and that will control how both the alarm and the watch show time.
    For a few others, you get to select A or P or H separately from the numbers, either while setting the time or while setting the alarm.
    The Chinese factories that build these watches seem to put any of the different kinds of insides into any of the same cases, so you might have any version -- and the companies rarely bother making sure that the instructions match the actual watch.
    2helpful
    3answers
    Need to set time on WalMart TGHK watch.
    If its digital that makes it more difficult to give setting directions online. Need to know the exact model #. I would do a google search to try and find your watch and you might find a manual online. OR you could seek out a local watch repair business and they should be able to set it with no problems. Most Sears have a watch repair kiosk in their stores! I woudlnt take it back to Walmart because they are just sales people! They have limited watch knowledge!
    Jan 09, 2010 • Watches
    1helpful
    My daughter got a timex 1440 digital watch for Christmas there was no users manual in the package and none of us can figure out how to set the time, it is currently in military time
    Go to the timex web site "Timex.co.uk".
    Enter model number in the search box.
    Select "manuals/downloads".
    Select "product manual downloads".
    Enter model number in search box.
    Choose instructions from list.
    5helpful
    Ozon japan movt quartz watch manual
    I have a Japan MOVT watch given to me by my daughter. The battery died and i have not worn it in some time. I got the battery replaced now i can't set the digital time or the date, etc. What is the procedure?
    Dec 02, 2009 • Watches
    I need to know how to set this watch. My daughter lost the directions. It says SHP3167 on the back. Can you help me?
    Generally digital watches all set about the same.
    I believe your watch is a Sharp digital alarm/chrono by the number you give.
    Hold down the start/stop button in the right corner until the display begins to flash. Once the display flashes you can go through the fields to be set by pressing the mode button.
    Some digitals use a different combination but are all about the same.
    Sep 15, 2009 • Watches
    12helpful
    How to set up ladies roxy digital watch
    I found users instructions on roxy website at:
    http://www.roxy.com/search/index.jsp?f=Taxonomy%2FROXY%2F2818169&categoryId=2818071&f=Taxonomy%2FROXY%2F2818071&fbc=1&fbn=Taxonomy|Watches&fbx=0
    We were able to program our watch completely!!!
    If you look on the back of the watch that you bought on the metal plate, it tells you the style. Ours was the Roxy 70's digital watch, and I found specific instructions at (even if this is not your style, the instructions may work):
    http://www.roxy.com/graphics/uc/roxy/manuals/Roxy_manual_watch_70s.pdf
    1helpful
    Setting the analog
    If you find the 4 digit number inside a square on the back you can go to the casio website and pull up the manual that way.
    Top Watches Experts
    john h
    ADMIN Andrew
    ADMIN Andrew
    ADMIN Eric
    ADMIN Eric
    Are you a Watch Expert? Answer questions, earn points and help others
