Question about Pride Mobility Products New Pride Mobility Jet 3 Ultra Power Wheel Chair
When switched on power light flashes. - Pride Mobility Products New Pride Mobility Jet 3 Ultra Power Wheel Chair
Posted by bcrobertso on
lennieg2000
  • 692 Answers
How many flashes? Count number of flashes should be a slight pause then flashes the same number of times . Your manual will give you flash codes and you can determine what the problem is. If all the lights are flashing and there is no pause the chair could be in "lockout" Your manual should tell you how to get the chair out of lockout I think that Pride uses the joystick to get it out of this mode.. Turn the chair on move the joystick forward till you hear a beep then move the joystick to the rear until you hear another beep release the joystick and the lights should quit flashing Hope this helps
Posted on Aug 18, 2010
E120n ALL LIGHTS FLASHING
switch off you printer. pull out power cord from source, wait for 5 minutes then plug in back the power cord to the source and switch back ON your printer
Sep 02, 2015 | Lexmark E120n Laser Printer
No power but lights flash
Is there a reset switch. Most vacuums have one some where near the bottom brush, to protect the vacuum from overload. If the vacuum tripped, the vacuum will not work until you've pressed the reset switch. If you can't find one, pls check manual.
Mar 04, 2014 | Sebo Automatic X1 Bagged Upright Vacuum
My kobo wont turn on
How to Fix Kobo eReader Locked up Frozen or Not Responding
1)Slide power switch to right and hold for 15 seconds and release
    2)Slide power switch to right again and hold till green/blue button near switch lights up.
Dec 05, 2017 | iPhone Apps
When you switch on the set the light comes on flashes and goes of
Depending on what tv you actually have, it could definetively be a power supply problem if the light is flashing. I would suggest to get it professionally looked at, at a reputable repair center. Sorry, Good Luck!
Jun 11, 2009 | Samsung Televison & Video
Philips FTR 9964 tries to switch on but light above power switch flashes red
Jun 05, 2009 | Philips FTR-9964 Tuner/Receiver for Plasma
Only power light will power on for few seconds then flashes.
Does the main lamp light at all? It sounds light a cooling fan failure. If the fan iis not working the the main lamp will not turn on and the power light will flash.
Jan 07, 2009 | Optoma EP755 Multimedia Projector
Console switches itself off
If the power brick shows a red light, it means that it is not providing sufficient enough power to power the console. It is overheating and simply crashing. You will probably need to purchase or (if under warranty) get a new one.
Dec 28, 2008 | Microsoft Xbox 360 Console
D-Link Ethernet Switch Lights Flashing and No Internet
You seem to have a problem with the switch or its power supply. If you have another D-Link device with the same power supply (see the volts and amps on the sticker), we may try switching them.
I one had a problem very similar to yours and changing the power supply solved the problem.
Apr 16, 2008 | D-Link Express EtherNetwork DSS-5+...
Pride Mobility Products New Pride Mobility Jet 3 Ultra Power Wheel Chair Logo
978 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Bird
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
