Cisco Universal Access Server AS2511-RJ Remote Access Server Logo
Posted on Aug 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is remote access server? And what does it enables me to do?
tom sh
Level 3:
  • Master 1,141 Answers
  • Posted on Aug 12, 2010
tom sh
Master
Level 3:
Answers
1141
Questions
34
Helped
306003
Points
3511
Remote access allows you to connect your PC from a remote location using the Internet. The entire working environment of your computer is brought over the wire to wherever you are, eliminating the need for synchronizing between laptops and desktops.
2answers
What software should I use to bypass my university internet restrictions?
If the games are in fact, "yours" then you can configure your game server to publish on the normal HTTP port (80). Then, you will have no trouble at all.
I hope this is helpful,
--Robert
tip
VPN in Microsoft Server 2003
The full form of VPN is Virtual Private Network. VPN gives extremely secure connections between private networks linked through the Internet. It allows remote computers to act as though they were on the same secure, local network. Allows you to be at home and access your company's computers in the same way as if you were sitting at work.
Almost impossible for someone to tap or interfere with data in the VPN tunnel. If you have VPN client software on a laptop, you can connect to your company from anywhere in the world. VPN goes between a computer and a network (client-to-server), or a LAN and a network using two routers (server-to-server). Each end of the connection is a VPN "endpoint", the connection between them is a "VPN tunnel".
When one end is a client, it means that computer is running VPN client software. You can use a virtual private network (VPN) to connect components to one network by using another network. VPN do this by "tunneling" through the Internet or another public network. With a VPN, connections across the public network can transfer data by using the routing infrastructure of the Internet, but to the user, the data seems to travel over a dedicated private link.
A VPN gives you the benefit of a dial-up connection to a dial-up server, plus the flexibility of an Internet connection. Using an Internet connection you can connect to resources all over the world. If you have a high-speed Internet connection at your computer and at your office, you can communicate with your office at full Internet speed. This is much faster than any dial-up connection that uses an analog modem.
VPNs use authenticated links to make sure that only authorized users can connect to your network, and they use encryption to make sure that others cannot intercept and cannot use data over the Internet. A Tunneling Protocol is a technology that helps make the transfer of information over the Internet more secure from one computer to another.
VPN technology also permits a corporation to connect to its branch offices or to other companies over a public network, such as the Internet, while helping to maintain secure communications. The VPN connection across the Internet logically operates as a dedicated wide area network (WAN) link.
VPN in Windows 2003 Server: You need a high speed Internet connection to configure and run VPN server. Two individual lan card must be present in a single system where you want to configure a VPN Server. The lan cards should ping each other. Also need a User which's Dial in allow access should be enable. Microsoft 2003 server two tunnelling protocols for a secure VPN connection, one is PPTP (Point-to-Point Tunnelling Protocol) which Provides data encryption using Microsoft Point-to-Point Encryption. The other is L2TP (Layer Two Tunnelling Protocol) which Provides data encryption, authentication, and integrity using IPSec.
Steps to create VPN Server in 2003 Server: At first I go to Start and point to Administrative Tools, then click Routing and Remote Access. Then I click the server icon that matches the local server name in the left panel of the console. If the Routing and Remote Access service was previously turn on, you may want to reconfigure the server.
To reconfigure the server Right-click the server object, and then click Disable Routing and Remote Access. Click yes to continue when you are prompted with an informational message. Then Right-click the server icon and then click configure and Enable Routing and Remote Access to start the Routing and Remote Access Server Setup Wizard. After that click Remote access (dial-up or VPN) to turn on remote computers to dial in or connect to this network through the Internet. Then I have Click to select VPN. In the VPN Connection window I click the network interface (Lan) which is connected to the Internet and go the IP Address Assignment window, then I click Automatically because there was present a DHCP server in network. However, if DHCP is not available, you must specify a range of static addresses.
If you use from a specified range of addresses, open the Address Range Assignment dialog box and Type the first IP address in the range of addresses that you want to use in the Start IP address box. Type the last IP address in the range in the End IP address box. Windows calculates the number of addresses automatically. After that I have accept the default setting of No, use Routing and Remote Access to authenticate connection request and finally Click Finish to turn on the Routing and Remote Access service and to configure the server as a Remote Access server.
For the remote access server to forward traffic properly inside your network, you must configure it as a router with either static routes or routing protocols, so that all of the locations in the intranet are reachable from the remote access server. It also need for security purpose.<SPAN style="LINE-HEIGHT: 115%; FONT-FAMILY: 'Verdana','sans-serif
I am trying to setup my set up a Access Point at my house with the following product. a EnGenius EOC 2611P. when i set security on the device it is not sending an ip address to the computer. is there a...
Assigning an IP address to a computer is a function of DHCP. Either the access point's DHCP server much be enabled, or a DHCP server somewhere on the network to which the AP provides a path must be enabled. There should be only one DHCP server per LAN.
For example, if you have a home router handing out DHCP addresses to computers in your home, and you wire this AP to your router to wirelessly serve an additional computer or computers in a remote location, then its DHCP server should be off, because DHCP service will be performed by your home router to both local and remote computers.
However, if you connect this AP directly to your network interface and serve ONLY computers in a remote location, then its DHCP server should be on, so that it will provide DHCP addresses to the remote computers (because your network interface in general won't, unless it is also a router itself, in which case see the previous paragraph).
1helpful
Zebra Z4m w/print server II has Netware enable, How do I turn it
The print server has a web access if you know the IP address. You may need to have a Username (root) and password to gain access to what you wish to change.
How to connect to my PIX 501 and use Windows Remote Desktop?
Here's a real simple problem to your remote access problems.
Go to: http://www.logmein.com
Sign up for a free acct, download/install their free software on your Server.
Now go over to your laptop, login to your new logmein acct.
In the next page, you'll see your Server listed. Click on it - follow instructions to connect.
This will tunnel through whatever stuff you have on your network!
Trust me - esp. in your scenario, this is *by far* the *simplest remote connect you'll ever perform! And it just .... works! Everytime.
gurutim
Access remote system devices
if need to access the device of your client,just follow the steps.
we take cd rom for eg to access.
1.right click the drive there you see "sharing and security"
2.click on the and enable share as cd rom.and give maximum allowed.
3.then from your system.Run->ip of the machine->enter.
4.it shows all the share file of the client machine
if want access remote desktop
1.enable the remote desktop connection in the remote machine
2.in RUN type MSTSC the remote desktop connection will popup.
3the type the ip of the client machine
Remote access
Yes it is. You can use the vnc server and client utilities for this. Install VNC server on all the linux pcs. Then install the windows version of vnc on the pc you want to connect FROM.
Give the ip address of the linux pc you wish to connect to, and lo, you get the same desktop that is on the linux pc. Of course you can configure password protection.
Another easy but techie way to connect is with telnet or ssh command after enabling these services on the linux pc.
HTH,
Deboo
Windows 2003 server standard edition
You have to enable routing and remote access in win2k server to share your internet connection
Follow these steps
Goto start--> programs-->administrative tools --> routing and remote access
Just click it
In the action menu click add server and select your server in the list
Once routing and remote access is properly installed in the server
Go to the client give gateway address to your server address and any internet DNS server addresses , and you can now acccess the internet
You can also use any internet sharing software , In this case i sujjest to use Sygate Internet sharing software
Good Luck
BEFSX41 and Microsoft PPTP
Microsoft uses IP Protocol 47 [GRE] for this secure tunnel. Provided that the PPTP Pass Through is set to Enable on the Router's Filters page and port 1723 is forwarded to the VPN Server, the Router will allow authentication and remote access into your network. The router will also allow you access remote PPtP networks from behind the router providing the PPtP Passthrough is enabled on the router.
Top Cisco Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
