Dear sir, We have 1 ups having problum with IGBT.We replace the IGBT again it faild Then check the ups 1 disc cap & diode is also gone.What will do next.
Very complicated these items. I have not been able to repair even apparently simple faults, manufacturers such as emerson/leibert do not release cct diagrams, so very difficult to fix as there are many different sections (pfc,rectifier,charger,upconverter,bypass,inverter) of the circuit all interconnected with a micro processor monitoring and controllling the whole thing. You have to be really lucky to sort out any problem particulary one with blown components.
Hope this helps
Thanks for using FixYa
The primary reason for E2-1 is that the drive board detects IGBT over current signal
Check the folowing.
A. Re-start the unit.
B. Inspect whether the servo motor wires are connected properly to the motor.
C. Replace the drive board.
D. Inspect the servo motor windings for a break. If so
E. Replace the servo motor
same with me, we have 2 faulty unit, inverter fault. i'll try to swap almost possible faulty component but still same prob.
