We just moved into a rental. It has the Fugitsu wall-mounted Air-conditioner model: ar-jw2 but, there was no manual left behind and we are trying to use the heat, however, it just blows cool air, we're not sure how to work this, and don't want to make it any worse. Please help...
  • Anonymous Aug 12, 2010
    Thankyou, but, it's set on "30oC"........???
Terence Fourie
  • 909 Answers
Look, if you select a temperature above ambient temperature, it will switch from cooling to heating.(assuming that the aircon has a heat pump. most do these days.) Just dont rush the aircon because every time you make a setting change, it takes a while to regulate.
Posted on Aug 12, 2010
    Thank-you, but we have it se on 30 degrees Celcius.....?
    Hi, am clueless with these things, I have typed in the model number for the remote not the unit itself. I was wondering if you could help me out if possible? Model # 30ABA-W Serial # T007480 Fugitsu, etc...
Korre Karmela
    New Friend:
The fujitsu comes with a remote control. Turn unit on with start/stop button and then hit the master control button. You should see heat in the remote control display if the fujitsu unit you have is a heat pump. If it strictly cools you will not have heat. Give the unit a couple of minutes to reverse the refrigerant and then using the set temp. Button set the temperature to your desired heat. This should do the trick.
Posted on May 26, 2013
Monika Arora
  • 503 Answers
This unit comes with a remote control (optional wall mounted wired thermostat available) as a standard feature. This unit is precharged with the environment friendly R-410a refrigerant. No additional refrigerant is needed if the line set is 49 feet in lenght or shorter. In addition to its very high 20 SEER efficiency rating, the 15RLQ is only 31 in. long which makes it the smallest Mini-Split System in its category through out the industry.
This category of equipment is ideal for smaller spaces where spot cooling is required. Several models in this category are ENERGY STAR Certified, meaning they save you money on your utility bill. Residential applications including sunrooms and additions are made easier with these air conditioners and heat pumps. Do you have a warm spot in your home? Fujitsu mini-splits can provide extra cooling capacity for those hard to cool areas. Commercially, their small size makes them ideal for small offices, providing individual temperature control.
Fujitsu's I.A.Q. Systems provide residential and commercial property owners an innovative solution for clean, temperature-controlled indoor air. The Halcyon IAQ systems deliver powerful heating and cooling, are designed for ease of use and maintenance, and feature an unobtrusive design which can be integrated easily into any decor. The Halcyon IAQ systems filter dust, pollen and odor making them the perfect addition to any home!
  • Wireless Remote Control
  • Plasma Filter
  • Sleep Timer
  • 24 Hour Timer
  • Dry Mode
  • Auto Louver: Up/Down
  • Auto Mode
  • Quiet Mode
  • Auto Restart/Rest
  • Auto Changeover
  • Low Ambient
  • Cold Prevention
Warranty All Fujitsu ductless mini-split air conditioners and heat pumps come with a 2 year parts and 6 year compressor warranty.
Important: All installations must be performed or supervised by a certified HVAC technician in order for the warranty to be valid.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
The system cannot be turned on. Need a tech.
[PDF]Service Manual - Quietside
https://quietside.com/max/.../Service%20Manual_MAX%20Series.pdf
Samsung Electronics ... Users should not install the air conditioner by themselves. ...If this happens, turn off the air conditioner and contact an authorized service center.... Wall-mounted ...... In a COOL operation mode, the compressor does not.Samsung Electronics ... Users should not install the air conditioner by themselves. ...If this happens, turn off the air conditioner and contact an authorized service center.... Wall-mounted ...... In a COOL operation mode, the compressor does not.
Sep 28, 2015 | Samsung AQV36JA Classic 36000 BTU Single...
Need a manual to download for model FAH0818R1T
Good Morning Friend, this is Z. I am happy to assist you!
I see that you are looking for the manual of your Frigidaire air conditioner, FAH0818R1T; however, it appears above-listed model number is invalid. The serial, which lists your model number, is typically located behind the front grill by the air outlet or on the side of the cabinet. In the meantime, I have located the Owner's Guide to a similar air conditioner, model number FAH08ER1T1. Looking forward to hearing from you. Thank you!
Frigidaire Manual Search Results
Jun 15, 2014 | Frigidaire FAH086R1T Thru-Wall/Window Air...
MLG LS307HV. Condensation is dripping off the bottom of the indoor unit. We've mounted the unit level but the left side continues to pull up. The wall mount is level but he unit is slightly out of...
the inside unit should be mounted with a slight tilt to the outside - so the water can drain outside.
also - be sure your drain hole (in the unit) is not plugged - either with dirt/debris.
Aug 04, 2011 | LG LS307HV Air Conditioner
Putting a window air conditioner in the wall
I dont see a problem with these working in the wall, however you will probably need to install a condensate line to drain away the water that will be left from condensation. These items may be purchased from any hardware store.
Hope this helps Ya please rate me
Jun 22, 2008 | Heating & Cooling
Through the wall vs. window installation
window mount doesn't have to extend out on the back to clear the side /top intake vents because a window is about 2" thick,
but a wall mount has to have about 6 to 8 " clearing before the intakes vents can be exposed. you can't have your intakes buried in the wall.
in short if you see about 8 " of dead metal in the center area (just behind the window sill) then you can mount it in a wall as it will protrude far enough to clear the side /top intakes.
a sleeve just gives you a way to balance / attach to the outside wall
Jun 12, 2008 | Heating & Cooling
I just purchased an alleged "window mount" air conditioner with the closest dimensions to the existing model. Do these mount as through the wall as well? My current opening = 18 x 26" the new purchase is 16 27/32 x 26.
There are 2 different types of window air conditioners – there are the window type of which will fit in a window that opens top to bottom and there is the slide in model of which the actual air conditioner will slide into a metal sleeve which is very common in apartments. In either case you need to measure the inside of the metal sleeve and then give that to the air conditioner dealer and he will know what to do and there is also a POS (point of sale) @ the store of which will also assist you in the measurement of the A/C unit – the window unit you need to measure the opening of the window itself, I hope this was helpful
Apr 09, 2008 | Frigidaire FAC124 wall/Window Air...
Supplier of Wireless Remote for Fujitsu Split Air Conditioner
why want to replace remote.no idea abt w.canada
Dec 01, 2007 | Heating & Cooling
Heating & Cooling Logo
769 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
