NO POWER ON YAHOO LCD TV
No power , no led light on
The external Power suply is OK (127Vac to 12Vdc)
No schematic diagram
Yahoo LCD TV model YFP1779
Manufactured by Global Tech Apliances Inc.
(Global Display Limited model HT 179)
can you help me?
Armando Vázquez from Puebla México
Posted by BIZMARCK on
  • Anonymous Feb 12, 2009
    estoy revisando una television igual y al parecer el controlador del display PW131A-40 parece ser el problema, pero aun no estoy 100%, has conseguido el esquematico?
5 Related Answers
William
  • 188 Answers
SOURCE: Phillips 42PFP5532d/05 LCD tv, stuck in standby.
Check 15V line,12volts is too low.
Posted on Jul 27, 2009
SOURCE: No Power - Viewsonic N3252w LCD TV
you go to a service centre near your area who repear it
Posted on Sep 08, 2009
SOURCE: red light power blinking
power supply problem this can be done by a professional tv repair
Posted on Sep 12, 2009
Anonymous
  • 7 Answers
SOURCE: SOYO LCD TV Model DLYT032D
DO NOT SPECT TO FIND A NORMAL FUSE. THESE ONE IS LIKE BROWN COLOR AND ROUND. IT HAS THE CAPACITANCE ON THE TOP OF THE PLASTIC. IT IS NEXT TO THE POWER CORD CONNECTOR. (1.5 AMP.S / 250 VOLTS)
Posted on Jun 01, 2010
Anonymous
  • 3 Answers
SOURCE: my daytec LCD TV model LM37 does not power on.
There is a manual switch on the bottom of the TV. Just flick it on and it should start to work. The switch is well hidden. It had me for a while. I was ready to go back to the store.
Posted on Jul 03, 2010
I have an LG 55lm4700 that has no power led and no picture, wondering what might be the issue.
it sounds like a blown capacitor in the unit somewhere.
here are some tools you are going to have to have: ohm meter,oscilloscope, signal generator, soldering equipment,
grounding equipment, diagrams, schematics, test points, layout of circuits,
Sep 18, 2015 | LG 55-Inch LED LCD TV - 55LM4700 Cinema 3D...
No power, red led doesn't light. Power cord is
Manufactureres usually keep their schematics to themselves however you may be able to contact them to purchase a new power supply.
Jan 23, 2010 | Sceptre X37sv-Naga 37 in. LCD Television
Specification the power suply SDN650PS
For the Bullet camera day/night IR, 18 LED, 3.8-9.5mm the pwer supply is 6mm,12vdc power supply
Oct 12, 2009 | Tyco Electronics / Raychem T312M-Printer
SANYO DP26647 blank screen, please help
U have LED front power tv light come on and bliking?Than ur power suply it dead.Power supply board must be replaced.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board.
Sep 21, 2009 | Sanyo DP26647 26 in. LCD TV
04TA0691 power supply
Hi
I have a .pdf of the diagram - can you let me know your email so I can send it - it's too big to attach.
Glyn
Oct 22, 2008 | JVC AV-56WP74 56" Rear Projection...
Sony TV KV-X2973E uk model: no sound in SCART or AV1, AV2.
Do you have its schematics or service manual? This kind of problem needs detailed schematic diagrams of related product. Let me know, are you Tech-Person or TV-Repairman?
Aug 15, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Won't work on ac
1. Make sure the AC power source is ok.
2. Make sure the AC power cord is good with no damage.
3. Look to see if there is a reset button on the rear of the set. If not, then look for a blown AC fuse inside the set.
Since the set works fine on +12VDC, the majority of the TV set is ok. You have a problem in the AC power supply. It could be a blown fuse, bad rectifier / regulator, bad step-down transformer.
The TV typically runs from +12VDC. The AC supply steps-down the 120VAC and rectifies it into +12VDC to power the TV. At some point in the TV, there is junction point where the +12VDC from the sets internal AC supply meets the external +12VDC power source. Usually they are electrically isolated from each other with a switch or with diodes.
Please let me know if I can be of further assistance to you.
- Jim
Mar 04, 2008 | RCA E13335GY TV
For Sony KV-1415WR problem
Hiii...
First :
what chassis your tv set have ?
#2 : Where exactly the location of D608 ?
#3 : How may time the LED Blinking ? like we all know Sony have selft diagnostic with it ?!
I hope hear from you soon...
Thank's
[Vrya]
e-mail : [email protected]
Oct 08, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
106 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
