The spool service basically holds what you want to print in memory and print it while you can do other stuff..
Check you spool settings here:
Although you can control whether to use spooling or not, you'll typically want to spool documents you send to printing. Spooling documents expedites the printing process, and allows the application that sent the document to release control back to the user much faster
this link will show you the settings you can select but the real settings will take place inside your printer properties.
http://technet.microsoft.com/en-us/library/cc739118(WS.10).aspx
Hp 1020 spooler settings, unable to find the specific one but i believe when you go into the options just follow the steps provided in the link with similar images and try selecting a different spooler option, this can indeed affect what's happening with the printer versus the systems...
http://technet.microsoft.com/en-us/library/cc722526.aspx
