Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
My esp-7 won't print in 8x10 size and does not print full page photos. My esp-7 won't print in 8x10 size and will not print full page photos.
Posted by joail800 on
Anonymous
    Sergeant:
  • 238 Answers
Check the page setting of printer.
Posted on Aug 12, 2010
Will the hp photosmart printer use 8x10 photo paper?
You will have to check the equipment driver itself. While attempting to print, try changing the page size (go to page setup). This will give you an idea.
Sep 07, 2014 | HP PHOTOSMART 7520 E-ALL-IN-ONE
How do I reduce an 8x10 photo to a 5x7 photo?
Are you using windows vista? If you are, here's what to do. Open the picture using windows picture viewer (right click the pic., click "open with" then click "Windows picture viewer" when the window opens, on the right, click "full page photo" (the top one) then click 2options" then "printer properties" Under "paper size" click " 5"X7" Borderless or 126X178 Borderless. Click "OK" then click "Print"
Et voila!
Hope this helps.
Jan 11, 2011 | HP PhotoSmart C4180 All-in-One Color...
My Kodak ESP 3 Won't Scan
Did you install the full software driver for the all-in-one? The drivers are here: http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9103/12666/12667&product=EKN034524
Next try a new USB cable and plugging the unit into a different port. If you use a print server or USB hub, try connecting directly to the computer. Scanners need bi-directional communication with the computer and thus are likely to have issues even if the printer doesn't.
Can the scanning software on the computer initiate the scan? (That is in the full software package. Alternatively Vista came with Paint and File> Import from Camera or Scanner > New Scan.)
I hope this helps.
Apr 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
I can't get my X5070 printer to print normal size photos. It will print 8X10 but not the 4x6 size photo.
Have you correctly set the page size to 4 X 6?
Are you using the printer in stand-alone mode or are you printing from an application?
Don
Oct 26, 2009 | Lexmark X5070 ALL-IN-ONE InkJet Printer
Constantly cleaning the print head
I feel you should take it back. Under warrantee?
May 01, 2009 | Kodak ESP 5 Printer
Settings for printing a borderless 8x10 on a canon i9900
Downloaded following program for Vista and was able to print borderless pictures on Canoni9900
Easy-PhotoPrint EX Ver.2.0.3 (Windows Vista/Vista64/XP/2000)
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=232&modelid=9870#DownloadDetailAct
Mar 02, 2009 | Canon i9900 InkJet Photo Printer
Printing 4x6 photos on photo paper
Sorry but your question seems to be unclear.
Here are the solutions that I see:
- try fixing the orientation of your paper on the printer:
-- go to printer "properties" then select "paper" then set it to
landscape or portrait. You might just have to cut the extra
papers
- try changing the paper size on the printer "properties" if it has
no 4x6 then choose "custom size"
Jan 19, 2009 | Samsung CLP 300 Laser Printer
I purchased a C6280 all-in-one printer on 7-2-08.  Iwould like to know how do I print 5x7 and 8x10 photoson an 8x10 photo paper.  I can not find out how to do it looking through the manual. ...
We neeed to manually set the size of the paper in order to print on abaove paper sizes.
Open the HP Solution Center and click on settings >> print settings >> printer settings.
Now select the paper type as plain paper and click OK.
Now click on custom settings and enter the size of the paper and give it a name and click OK.
Now close the solution center and reopen it again.
Now click on settings >> print settings >> printer settings.
Now check whether we have the name that we gave to the custom size previously. Select it and then click OK and then try to print.
Jul 04, 2008 | HP Office Equipment & Supplies
Only prints 4x6
Check the printers console settings for correct page type and size.
Mar 27, 2008 | Epson Stylus Photo R320 InkJet Printer
Printing
no worries, check for up to date printer drivers here
and then, make sure settings and paper selection are matched to what's in your tray
Dec 28, 2007 | Canon PIXMA IP5200 InkJet Photo Printer
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
181 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
