Hello Tracy,
Most likely the problem why the freezer work but the refrigerator doesn't is going to be a problem with one of the components of the automatic defrost system....do you see a bunch of frost built up on the back wall of the freezer?? If yes ya do frost build up on the back freezer wall it is a defrost problem.Here is what to check to see why its not automatically defrosting.
DEFROST HEATER ...remove back wall of freezer and you will see a black heater at the bottom of the coil thats frosted up,it looks similar to the bake element in your oven,or in some cases it is going to be a spiraled wires inside of a glass tube. To check it,use a
multimeter set to the lowest ohms of resistiance setting and follow and find the
wires at the top of that frosted coil,unplug/disconnect those wires and check for continuty with around 5-20 ohms of resistiance. If it has that amount of ohms the heater is good. If your meter display does not change or displays OL the defrost heater is broke and needs to be replaced
DEFROST TERMINATION THERMOSTAT... it's round and has 2 wires and clips to the top of that frosted up coil. IT MUST BE CHECKED WHEN COLD SO BEST TO DO WHEN FROST IS STILL BUILT UP. To check it disconnect the wires on it and check for ZERO ohms of resistiance. As with the heater if the meter display OL or doesnt change,it is the problem
DEFROST TIMER...it is
not in the freezer but intstead in the control panel in the ceiling of the refrigerator. It has a center hub on it that can be turned until the fan in the freezer and the compressor cut out..then within 5 minutes of the fan/compressor shuts off the defrost heater should be on. If the heater is on within 5 minutes the defrost timer is the problem...if the defrost heater does not come on it will be either the defrost heater or termination thermostat that will be the problem.
Here is what the parts look like;
DEFROST TERMINATION THERMOSTATDEFROST TIMERDEFROST HEATER Good luck,i hope i have been able to help you fix your refrigerator,
GENE
