Question about Brother MFC-7820N Printer
Paper feed jams. feeds from lower tray, turns 180 deg. then jams. Single sheet feed is fine
Posted by sbower on
Anonymous
    New Friend:
  • 67 Answers
While keeping the paper .. ensure that it is properly stacked... fan the paper and ensure that it is not stuck to each other.. also open the printer cover and see if any paper is stuck inside..
Try to open the rear access door ,and clean the paper roller with slightly damp lint free cloth
Posted on Aug 12, 2010
Dell 1720 printer single-sheet feed stopped working
Pull out the paper that is jammed and continue.
Nov 29, 2012 | Office Equipment & Supplies
Canon Inkjet, Not Printing?
Hi Rosa,
There was a paper jam and you cleared the jam, however you missed out to do one other thing. Cleaning the Rollers.
If the Paper Feed Roller is dirty or paper powder is attached to it, paper may not be fed properly.
In this case, clean the Paper Feed Roller. Cleaning will wear out the Paper Feed Roller, so perform this only when necessary.
You need to prepare: three sheets of A4 or Letter-sized plain paper
1.Make sure that the power is turned on, and remove any paper from the Rear Tray.
2.Open the Paper Output Tray gently, and open the Output Tray Extension.
3.Clean the Paper Feed Roller without paper.
(1) Press the g0081065_tcm14-774017.jpg (Maintenance) button repeatedly until b appears.
(2) Press the Black or Color button.
The Paper Feed Roller will rotate as it is cleaned.
4.Clean the Paper Feed Roller with paper.
(1) Make sure that the Paper Feed Roller has stopped rotating, and load three sheets of A4 or Letter-sized plain paper in the Rear Tray.
(2) Make sure that b appears on the LED, then press the Black or Color button.
The machine starts cleaning. The cleaning will be completed after the paper is ejected.
This should fix the issue
Regards,Suhail
Nov 03, 2011 | Canon PIXMA MP495 InkJet Printer
Brother MFC-8840D printer w/false paper jam indication.
With my Brother 8840D I have had paper jams that when cleared would not delete from the display nor would the machine operate until I unplugged the machine for around eight hours. I guess it is a sort of reset or reboot.
Jun 06, 2010 | Brother MFC 8840D All-In-One Laser Printer
Will not feed paper of any size. No jams ever.
clean the feed rollers with water and soft cloth.. try a stack of paper not a single loose sheet
Aug 15, 2009 | Epson Stylus 1400 InkJet Photo Printer
Will not pick up paper from tray. Red light blinks indicating a paper jam. Prints fine if single sheet thru bypass slot.
Not picking up paper indicates either a worn nip roller (rubber on feed spindle) or you have a broken gear in the feed mechanism.
Aug 14, 2009 | Brother HL-2040 Laser Printer
Printer can't feed paper from tray
You may need to clean the rubber feed roller with a damp towel, water only, or if parts are broken or missing, a new paper tray, around $20.00
Jul 20, 2009 | Brother HL-5240 Laser Printer
My laserjet 1020 develops a paper jam after printing the first page of a multipage print instruction .I have deleted the printer and re-installed it including all drivers but problem still...
Reinstalling the printer is related the Software.
If the paper gets physically jammed than its the driver setting issue or hardware issue.
Check if two sheets get jammed or only one sheet.
If it is two sheets than printer is picking up multiple sheets and paper gets jammed.
If the printer is jamming a single sheet than remove the Tray and look there is rubber roller inside if there are marks or lines on that rubber roller or if the roller roller is worn out than that rubber roller called as paper pickup roller need to be replaced.
If that looks fine than try to priny using manual feed and if the problem persists from manual feed too than try another toner cartridge
If the problem is not from Manual feed Tray that Replace the main Tray with known good Tray and check if the issue resolved.
Jul 01, 2009 | HP LaserJet 1010 Printer
HP paper jam
That is usually caused by the paper feed rollers being cover with paper dust. Take a clean cotton pad and alcohol and clean the rollers :turninig each roller as you clean it. if it has a rear dor, open it to get better access to the rollers.
Please remember to rate all users who assist you for free :)
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 03, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
Paper feed/jamming problem
suggest you bring your orinter to the nearest authorised repair center. There might be parts to be replace
Mar 23, 2008 | Brother HL-2040 Laser Printer
Brother MFC-7820N Printer Logo
354 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
