Question about Jet 1HD Power Electric Wheelchair
Trying to replace the grommit on the joystick can you help?
Posted by elsig on
frank thomas wilson
  • 10,319 Answers
I see the controller has the grommet alongwith that part. I see no grommet listed separately
Please copy and paste this link below to view the diagram I have found for your wheel chair
http://www.southwestmedical.com/replacement-parts/pride-mobility/jet-1-hd/joystick-master-controls/vsi-controller-replaced-pilot-dl50-controllers/controller-assembly-vsi
Posted on Aug 12, 2010
M51 powerchair having controller fault (light flash 7x) is there a reset or something i can try at home to fix?
Nope unless you have another joystick. Try unplugging the joystick cable at the joystick and plugging it back in turn on and see if it makes a difference. If you are still getting the error you will need to have the joystick replaced sorry
May 03, 2011 | Health & Beauty
Our church has 2 Jazzy's one is blinking the code all lights flash 7 times the other 9 times all lights flash can not find what I need to do in our book. Can you help is there a web site I can get a...
mtp see the below list
The listed Flash codes are pretty standard and are applicable to powerchairs only not scooters:
1 flash User Fault (do not touch joystick) and turn back on
2 flashes Battery Fault Recharge batteries or replace
3 Left motor fault check connections or replace
4 Right motor fault check connections or replace
5 Left park brake fault check freewheel lever or brake connections
6 Right park brake fault check freewheel lever or brake connections
7 Remote fault check connections and wiring replace remote(joystick) (Check cable to the joystick unplug connector at rear of chair and plug back in then try turning on to see if you are getting same code)
8 Controller fault Check connections and wiring replace controller
9 Communication fault check cable replace (almost same problem as 7) try same fix if doesn't work joystick will have to be replaced
10 and 11 are unusual and will not be seen if at all Hope this helps you
Apr 04, 2011 | Pride Mobility Products Health & Beauty
I have a problem with my psp1000.when i remove the joystick and i try to play a game use only a joystick.my character just keep on running in left direction and i cant control it.it's like it has a mind of...
The reason your character is moving by itself is your joystick malfunctioning. This is due to long playtime and hard pressing of joystick. It could also be that it has dust in it that's why it's malfunctioning. If it is still under warranty why don't you bring it to the nearest shop and let them fix it for you. You can also clean your joystick first from any dust and check if it solved your problem. Try watching this for your guide in cleaning the joystick of your psp. Be very careful in doing this or it might make your problem worse. If you want you can replace your joystick, I have checked it ebay and the price range from $2 - $3..
I hope this helps. Have a nice day!
Mar 08, 2011 | Sony PlayStation Portable (PSP) Console
Don't run light go from left to right on a "Jazzy
carly that indication is the charging inhibit mode and the joystick still thinks the charger is still plugged in. Unfortunately there is no quick fix for this and usually requires a joystick or controller replacement. I would have your provider check it for you and maybe try another joystick from another chair to see if that fixes the error if it does then you'll have to replace the joystick. If Medicare paid for your chair then they will pay for most of the replacement cost Hope this helps
Nov 18, 2010 | Pride Jazzy Select 6 Indoor Power...
Blazer 2004 gear jammed on R wil not move, car not switching on
try checking the shifter cable... there is a rubber or plastic grommit where it connects to the transmission. you may have to replace the shifter cable.
Aug 15, 2009 | 2004 Chevrolet Blazer
Pcv valve
This is a ***** trust me I done it, I have the same car. Don't unless the valve has stoped working even if it has its not a big deal its just an emissions control device. you need a black rubber grommit, the pcv vavle and a new piece of small black hose with small metal clamp. If you go to a dealership they have special pices you can buy to make it easier. When doing this the grommit and hose might as well be replaced also they are small and inexpensive parts readiley available, just dont drop the old or new peices or push the old grommit into to itake maifold like I did. Peace
Sep 16, 2008 | 1989 Oldsmobile Delta 88
Psp joystick
well psp were built to have its own joystick, other joystick are usually generic versions, so the chances of them being faulty for psp are high
Feb 10, 2008 | Sony PlayStation Portable (PSP) Console
Cant go left on joystick last solution no good
see buuddy if u have allready triesd with blowing out the dust from joystick part than go for the change of the keypad(joystick). the problem might be with the joystick it might have got broken so change the joystick and than try.
Oct 11, 2007 | Nokia 6600
Cant go left with the joystick more in msg
remove joy stick rotate it by 90 degree & insert it again.there r 4 points beneath it for 4 directions ,it is not sensing the left one .otherwise u can replace the joystick from nokia care centre.
Oct 09, 2007 | Nokia 6600
Nokia 6600 joystick problem
i have a friend in the Philippines, a known celfone technician in his own right, but he has a knowledge in replacing joystick of several phone models/brands. this is his e-mail address [email protected] He could be of great help to you.
Jun 06, 2007 | Nokia 6600
Jet 1HD Power Electric Wheelchair Logo
Top Jet Health & Beauty Experts
Marvin
Marvin
Vincent G
Vincent G
ray gallant
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
