Question about RCA 36V430T 36" TV
I have a RCA 36v430t tv i just got from someone i was watching a movie it just went off could it be a fuse
Posted by lovemy72chev on
2 Related Answers
Vista Electronics
  • 1694 Answers
SOURCE: rca 36" F36685
YX2 = part # 244247..................................................T.
Posted on Jan 15, 2008
zimcloud
  • 135 Answers
SOURCE: 36 inch RCA tv (model # 36V430T)
I wouldn't advise doing it yourself. All you have to do to kill yourself is touch the wrong part connected to the magnets on the back of the tube-even if it has been unplugged for a couple of days- no joke. The repair place will be better able to track down the part, and install it, and guarentee it. Be aware- it might take a week or two for them to just get the part-then they have to install it.
Posted on Jul 02, 2008
My Rca 36v430t come on and then off then on then off over and over what wrong
There are shorted component/s on the main board of the TV. Check the horizontal output section for fault.
May 28, 2012 | RCA 36V430T 36" TV
38 '' RCA TV XBOX Model 36V550T, lost the picture
Does it only happen when you use your Xbox?
Try pulling the cable in and out between the TV and Xbox
Dec 05, 2009 | RCA 36V430T 36" TV
TV will not turn on
There is a problem with your power ic..U need to replace it...
Dont forget to rate
Sep 07, 2009 | RCA 36V430T 36" TV
Picture went out on my 36'' RCA television, still have sound.
do you have and big sound system if you do the move them away from youur tv. or you sould just bring it to a shop it must be the picture tube
Jan 26, 2009 | RCA 36V430T 36" TV
RCA 36V430T will not turn on
Larry,
I had the same problem yesterday. My wife's uncle is a tv repairman for a major electronics chain. He came by last night and had a look at it. It turned out to be a very inexpensive transformer that went bad. The part itself is only a few bucks. Hope this helps and its not too late.
Nov 09, 2008 | Televison & Video
36 inch RCA tv loses picture and sound, but power stays on
Cable Looses signal power after 20m ... Install signal amplifier
https://youtu.be/AkiKf4G4UE0
May 04, 2017 | RCA 36V430T 36" TV
My new universal remote
Jo have you plugged in the Audio and Video cable in correctly. You need to check that the Video cable is in the corresponding input on the TV
Jun 08, 2008 | RCA Universal Remote Control
TV WON'T COME ON
If the fuses are good and the on indicator lights you could have a short in the power supply, the high voltage section or just about any part of the circuitry. The most common problem is the high voltage. If you know TV safety and how to check transistors, unplug the unit and check the horizontal output transistor. If it is shorted replace the transistor, flyback and HV divider. If this does not solve the problem you will probably need a repair tech as this symptom could be a short anywhere in the unit. Good luck and remember to be safe.
Jun 30, 2006 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 36V430T 36" TV Logo
Top RCA Televison & Video Experts
Paul Bade
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
