Question about Sony Televison & Video
I have a sony projection television. I was watching it and accidentally cut it off. When I went I turned it back on it is not powering back up. I am seeing the red light on the front blink a few times and hearing it click in the back like it is trying to start but getting no picture and then hearing it click again and going back off.
Posted by sundaygun on
  • sundaygun Jan 19, 2011
    the model number is KDP-57WS550 It is a 57" projection television. It blinks ten times currently when I try to turn it on. It has blinked many different numbers of times when it is not working though. I have been using it and only cutting it on in the morning and cutting it back off at night and it has worked as long as it has time to drain during the night. It has not quit working all together though and is blinking ten times. Thanks for any info you can provide.
Anonymous
  • 160 Answers
Hello.
My name is Russ. Maybe I could help you, but I need to know model number of your TV (it is located on the sticker at the back of your TV next to serial number of the unit). Also I need to knoe exactly how many times red light is blinking. It does it repeatedly. Foe example: six blinks, pause, another six blinks and so on.
Regards.
Posted on Aug 11, 2010
    Hey Russ. The model number is KDP-57WS550. It is currently blinking ten times and then pausing and blinking ten again. I have been using it and just cutting it off at night and cutting it back on in the morning and it has been working and blinking different numbers of times when it did that but now it is not working at all and is blinking ten times. Any info you have would be appreciated.
Sony 60 wega rear projection started cutting off on its own....green light flashes multiple times then comes back on. Cuts off again after a minute or two.
Does the LAMP light beside the LED power light flashes too?How long is it been u change the projection bulb?If u watch alots of tv,and it has been along time,u have not change the bulb?The first,thing to tries is to change the projection bulb,see how in turn out?
Mar 20, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
50 inch Plasma problem
Most likely a capacitor in the power supply went out. otherwise it may be a bad relay if there happens to be one.
Most reason for a tv not turning on at all is bad power supply
Aug 01, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Power green light will flash then flash red when first turned on
Please intimate exact model of your Sony TV to find out reason of no power up.
Jul 09, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Blue screen sony
blue crt shorting use crt restorer to lift short or replace picture tube /crt
Aug 19, 2008 | Sony KP-46WT500 46" Rear Projection...
No power
Good Day, jennylo04;
You need help??? I need help, too!!
Please help me by providing a MODEL NUMBER. OKAY??
Thank you, big IRISH,.
Aug 07, 2008 | Televison & Video
Power cuts out on PT-53WX42
unplug tv check the fuse and the rating on it,.see if filament inside is burnt
Oct 23, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Sony Grand WEGA KF50WE610 50 in. Rear Projection HDTV ready
Your projector bulb burned out, easy to replace yourself
Oct 07, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Televison & Video Logo
Top Sony Televison & Video Experts
Nasir Muhammad
Nasir Muhammad
Demonic-2011
Demonic-2011
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
