LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive Logo
Question about LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive
My mac wont find my lacie external hard drive
Posted by bparis8181 on
Anonymous
    New Friend:
  • 92 Answers
Do u connect it in the keyboard? if yes then that doesnt work cause it doesnt have enough power to go through the keyboard. if u connect it in the back of mac then it should work
Posted on Aug 11, 2010
1helpful
Is Model Lacie 301442U compatible with Mac Pro 10.4.11
According to this website http://www.product-reviews.net/review/20090204/lacie-301442u-1tb-external-hard-drive/ it is compatible with a mac. Hope this helps.
Trying to drag all files from itunes into lacie 250 g design by porsche hard drive and it won't let me.
Thank you for asking your question with FixYa Support.
I am not sure what type of computer you have that your LaCie is connected to, but first and foremost, make sure the external hard drive has been properly formatted to work with the operating system your computer has.
For Windows computers: the LaCie should be formatted in either FAT32 or NTFS (recommended- more secure).
How to Format a HD in Windows Vista
For Mac computers: the LaCie should be formatted in Mac OS Extended (Journaled) format.
How to format an external hard drive in Mac OS X
If your LaCie is already formatted, then the best way to import your entire iTunes library from the internal hard drive of your computer into the LaCie, especially if you are unable to drag and drop the library into you LaCie, is to try a simple copy and pasting of the ENTIRE iTunes folder from its home on your computer to the LaCie hard drive.
You can also use the website I like to reference which provides some good alternatives to effectively migrating your iTunes Library from a PC or Mac to your external hard drive:
Here is that support link:
How to Transfer iTunes Library to another Computer
(also included in this article, are external hard drives)
For sake of space, I want you to review this article, because I not only agree with its content, it is exactly what I would explain to you as well in a more condensed, easy to follow fashion.
I hope I have helped guide you well on your question.
Regards,
-Mactechtrainer
My lacie external drive wont transfer my data from a mac to a pc
Basic Troubleshooting:
-Check all connections (Ethernet, Power, USB, etc)
-Install the appropriate driver for the device, usually included on a CD
-Double Check compatibility with your system (system requirements usually on packaging of product)
-If you haven't rebooted since you set it up, then reboot, this fixes a lot of things
-Try the product on another computer
-Try different cables/ports on the comptuer.
If nothing works, then send it in if it's under warranty or contact a professional service.
Plus de lecture sur mon MAC
LaCie externe USB 2.0 500 Go 7200 tr / min de 500 Go Disque dur
Je un ne sais pas exactement ce que vous faites référence en ce qui concerne la
fonctionnalités de votre Lacie avec votre Mac, comme je l'aurais plus besoin de détails
de vous. Mais, au moins à vous diriger dans la bonne direction.
Tout d'abord voici le lien pour votre externe LaCie USB 2.0 500 Gig
Disque dur pour plus de soutien de LaCie:
Lien:
* LaCie externe USB 2.0 500 Go 7200 tr / min de 500 Go Hard Drive Support
En outre, si, pour plus de soutien pour des problèmes avec ce disque dur, y compris si nécessaire d'avoir à reformater votre disque dur, voici le lien:
Plus de dépannage pour votre LaCie externe USB 2.0 500 Go HD pour Mac.
Si vous avez besoin davantage d'aide, laissez-nous savoir si ces liens de soutien ne permet pas de résoudre votre problème actuel avec LaCie. également fournir des précisions sur la question, afin que nous puissions mieux vous aider.
Observe,
-Mactechtrainer
1helpful
Will erasing my LaCie ext HD impact any files on my Mac Book?
It will only effect thoes stores on the external harddrive. You will have to check the contents of the LaCie drive and see if it has any files you typically access from your Mac Book. Other then that no it will not effect files stored on your Mac Books drive.
LACIE 500 GB HARD DRIVE
i use my external hard disk many times but now when i connect my lacie external H.D to PC it dose not recognized
My lacie is making clicking noise like clock
Hello
Have a look at the link below, it should be of help.
Click HERE to navigate.
Please feel free to let me know of you have any further questions.
Kind regards
Lock123
1helpful
Lacie 320 GB Hard Drive acting as if full when it's not.
Simplest solution: back up the data on the drive and repartition it (which will wipe it). Otherwise it sounds like it could be a problem with the file tree or structure of the drive, the configuration files could be corrupt, some program could have stored temporary files in a hidden place that cannot be deleted without making the program delete them, etc. If you are on a mac, spotlight Disk Utility and use it to repartition. If you are on a PC use the search thing from the start menu and find a program called disk management (or something similar to that, you'll know it when you see it.) external drives are annoying. i kick mine into the wall periodically for good measure.
Top LaCie Computers & Internet Experts
Marvin
Marvin
shadow
Mike
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
