Question about Epiphone Music
Where can I get the wiring diagram for an Epiphone Les Paul Special with 2 pickups, and a single volume/tone/selector switch?
Posted by glassd on
Michial Gueffroy
    President:
  • 1,140 Answers
Try here:http://www.google.com/imgres?imgurl=http://www.electric-guitar-info.com/images/Epi-wiring-circuit1.jpg&imgrefurl=http://www.electric-guitar-info.com/les-paul-wiring.html&h=348&w=503&sz=48&tbnid=aSO6CWOP8JpBPM:&tbnh=90&tbnw=130&prev=/images%3Fq%3DEpiphone%2BLes%2BPaul%2BSpecial%2Bwiring%2Bdiagram&usg=__tWQm6BV6hWlRkesXsvExeuCGPcI=&sa=X&ei=emZjTP3YCsH38AaV7q2vCQ&ved=0CBgQ9QEwAQ or here:http://www.guitarpartsshop.co.uk/acatalog/electric-and-bass-guitar-circuit-diagrams.html
Posted on Aug 12, 2010
1 Related Answer
Michial Gueffroy
  • 1140 Answers
SOURCE: Wiring diagram for Les paul special II
Try here:http://www.seymourduncan.com/support/wiring-diagrams/ or here:http://www.gibson.com/en-us/Support/TechSupport/
Posted on Oct 17, 2009
What Epiphone model did I purchase?
Sounds like perhaps a Les Paul Special II, but more detail is needed to say for sure. There was a lot of variation in their Les Paul models. Posting a photo of both sides and the headstock is best.
-Has the guitar any binding, and what colour?
-Is the back of the guitar white or all black?
-Exactly what is on the front of the headstock, 'Epiphone', the 4-diamond logo, anything else?
Feb 21, 2016 | Epiphone Music
I have an Epiphone Les Paul Custom Silverburst, and it's pretty new and has worked great until now. It seems my bridge pickup lost tone and volume for some reason. My volume and tone knobs are cranked...
Need more info: 1- does the volume control still change the level? 2-Does tone control still change the tone? 3- What happens when in the center position on pickup select switch? Put pickup switch in center position (both pickups active). Then take a coin and tap on the pickups. Does bridge pickup sound lower? Lastly remove rear electronics cover and inspect all wiring for something loose or disconnected.
Aug 26, 2011 | Epiphone Les Paul Special II Guitar...
Hello I have a les paul model 2004. I need to know how to wire up a toggle switch or a diagram for this epiphone. it had a wire that was disconnected inside. thanks
Go to this site and find a guitar with the same configuration of controsl, pickups, etc as yours to see typical diagram. With CAREFUL inspection and good lighting often you can see where the wire broke from.
Apr 16, 2011 | Epiphone Les Paul 100 Electric Guitar
Fix the wiring in a epi lp100
http://www.1728.com/guitar.htm
Its basic diagram #2.....but a twin pickup les paul is a twin pickup les paul!
May 06, 2010 | Epiphone Les Paul 100 Electric Guitar
Which knob does what on the epiphone les paul studio? there are 4 knobs and the only one i can figure out is volume.
I believe the top front is volume for the front/neck pickup...the top rear is for the rear/bridge pickup and the other two are tone knobs for the front and rear pickups.
Feb 10, 2010 | Epiphone Les Paul Studio Electric Guitar
Oct 17, 2009 | Music
Epiphone Black Beauty controls don't seem to work properly
The volume is a common problem ... Search for wiring diagrams for your guitar to find a better wiring. Or take it to a guitar repair centre to have it fixed.
To tell which pickups are selected with the switch if it doesn't have the little plate telling you, Turn one volume down and flick the switch one way so you can hear just one pickup.
Two ways of telling which one it is picking up ... A toppy tone is the one nearest the bridge ... a bassy tone is the neck pickup ... The middle selection on the switch is both coils selected ... If you cant tell by tone ... Tap the pick up and you'll soon hear which one you have selected.
Apr 18, 2009 | Epiphone Les Paul 100 Electric Guitar
HELP!
This is exactly how any 2 pickup, 2 volume, 2 tone, three way switch guitar would be wired from the factory. Best of luck!
http://www.seymourduncan.com/support/wiring-diagrams/schematics.php?schematic=2h_2v_2t_3w
Apr 01, 2009 | Epiphone Les Paul 100 Electric Guitar
Low volume on front pickup of Epiphone Les Paul
i have an old sg, and this happened to me too. the repair guy told me that inside the p/u, the windings were broken, resulting in a lower output. go on e-bay, and look up a neck pos. humbucker. there everywhere. or do yourself a favor, and do what i did. i have an epi. flying v, and epi. les paul. on e-bay, i bought gibson 57 classics. i put these in both my guitars, and i now have great sounding guitars. you will not belive the difference. good luck, scott
Jan 31, 2009 | Epiphone Les Paul Studio Electric Guitar
Epiphone volume and tone controls
The controls should be setup in pairs (as long as the electronics haven't been modified. The two closest to the pickups are the volumes and the other two are the tone controls. The top knob set should be your neck pickup and the bottom set is for the bridge.
Schematics and wiring diagram for the typical les paul (sheraton) controls:
http://www.guitarelectronics.com/product/WDUHH3T2202
Oct 27, 2008 | Epiphone Music
Music Logo
638 people viewed this question
Top Epiphone Music Experts
Robert Graf
Harrie
Marvin
Marvin
Are you an Epiphone Music Expert? Answer questions, earn points and help others
