HP PSC 1315 All-In-One InkJet Printer Logo
Posted on Aug 11, 2010
Printer indicates paper out when paper is in the paper holder?
Anonymous
Level 1:
  • Contributor 30 Answers
  • Posted on Aug 11, 2010
Anonymous
Contributor
Level 1:
Answers
30
Questions
0
Helped
7779
Points
81
Hi, There are a few things that can be causing this problem. I'd suggest you try the recommendations from HP concerning this. Please click on this link to access their page.
If you want, you may choose to just skip to solution 3 on the list. That is the 1st thing I would do. Normally the problem. Good luck.
Epson nx430 paper out problem
if it has paper then the paper holder may be aligned correctly, try adjusting the paper holder and filling the holder to the max with paper. Im not exactly sure whats going on you simply did not provide enough information. Good luck
https://www.6ya.com/mr.mike
2answers
How do you replace the thermal roll to get it to print
Make sure you are using thermal paper which is 57mm wide.
Open the printer cover. Lift the paper holder lever on top of the printer. Remove the old tube from the last roll if it is still in the bottom of the printer. Drop the new roll into the roll holder in the bottom of the printer. Make sure the paper is coming from the bottom of the roll rather than off the top as it unwinds. Pull the paper out the front of the printer and close the paper holder lever down onto the paper. The shiny side of the paper should be facing you as it comes out of the printer. If not, the paper will feed out blank during printing. If you are replacing the journal roll, slip the end of the paper into the slit in the takeup spool (black reel) and wind over a couple of times before dropping into place. Replace the printer cover and make sure the receipt comes out of the cut out in the cover.
Good luck.
Error code 5100 displayed with orange alarm and green on off buttons flashing on and off
According to the manual, Error message 5100 indicates: "Movement of the FINE Cartridge Holder is blocked. Open the printer
and make sure there is no little piece of paper or other
object keeping it from moving. Unplug the printer.Then disconnect the printer f
from the computer. Plug it back in and try it again.
My printer won't pus paper through for photos,
Hello.
That error message means that the cartridge holder is blocked.
Turn the printer off and then manually move the cartridge holder a few inches. The holder could just be stuck.
Hope this helps.
From the printer indicator,the printer is requesting for transfer fuser kit. the percentage is low,down to 0%. What is transfer fuser kit?
GENUINE HP COLOR LASERJET 2600 MAINTENANCE KIT - Kit Includes: 120V(220v) Fuser Unit, Tray 2 Paper Pickup Roller (D-Shaped Roller), Tray 2 Separation Pad Assembly - Includes The Spring Loaded Separation Pad In Holder Assembly - Genuine HP Part
1helpful
Last week i tried to print but it didn't work and appeared 5100 error. i have the pixma mp 170 printer... i don't know how i can fix it
Hello
The manual states that the error code 5100 is a result of:
Service error 5100 is displayed
Cause: Movement of the FINE Cartridge Holder is blocked.
Action: Clear the paper jam or foreign object that is preventing the FINE Cartridge Holder from moving, cancel printing from your computer, then turn OFF the machine and turn it back ON again.
You might see something blocking the printer head, check inside to see if there is a paper jam, staple, or some other object blocking the print head.
If this does not work, try resetting the device:
  1. Turn the printer off.
  2. Hold the button Resume / Cancel (red triangle in the circle), click POWER - indicator lights green.
  3. Release the button Resume / Cancel, keeping POWER.
  4. Click Resume / Cancel 2 times, keeping POWER, and then release all the buttons.
  5. When the indicator light Green - click Resume / Cancel 4 times!
  6. Turn the printer off button POWER.
Hope this can help you.
Best regards
Andrea
1helpful
Instructions on printing a 4 x 6 card or photo on my HP 4280 All in One printer. How to I set up the printer?
At the printer:
1. Remove any paper from the input tray
2. Put a few sheets of 4x6 (10 or so) in the same tray
3. Adjust the paper holder bar so that the 4x6 paper stays straight in place. The holder bar was holding the 8x11 paper in place.
On the computer:
Open a picture
Seect [File] [Print]
Select the photo printer from the list
Cick on [Preferences]
See the paper type? select photo paper
See the paper size? Select 4x6
Quality (Best)
[OK]
[PRINT]
I have hp all in one printer, model no-C3-100 PHOTOSMART SERIES.Now the problem is-when i giving the printing option it is not pulling the paper.the brown indicator always flickerng indicating that paper...
try to add some or more paper on the tray and clean the tab circuit of the carrier or the cartridge holder and clean also the tab circuit of the printhead...
Epson r220
The printer may have an internal error or a hardware issue already.
Ink pads full usually indicates if all lights are flashing and an error msg would pop up in your computer screen "parts inside..."
Here's what you may want to try.
Just turn off the printer.
Checked for obstructions or any foreign objects inside the printer.
Try to check from inside the printer where the ink cart holder is, from where you load the paper and from where the paper comes out.
Hp colouer laserjet 4500n printer 2nd paper tray dont work when i clear the printer memory it work properly for few day in this printer an error shows drum life low change the drum and tool kit
I would definitely suggest ordering the drum life kit and replace that. A lot of times the tray comes undone from the paper tray holders causing the rollers to not be able to pickup paper. Be sure all the plastic holders are snapped into place on the right paper size setting and check the rollers for dirt, glue or wear.
k24674
Grand Canyon Tech
Grand Canyon Tech
