Question about Avanquest Fix-It Utilities 8 Professional: Windows
I have removed Avanquest, but the Fix-It Utilities 'reminder' pop-up continues to interrupt what I am doing, urging me to update. How can I get rid of this or at least, stop it from popping up several times a day?
Posted by liaflight on
Bob
  • 245 Answers
If you're running anything older than Windows 7,go to Start,Run,type in msconfig,a couple seconds later a box will pop up with several tabs one of which is Startup.Open the startup tab and look down the list of checked boxes for anything having to do with Avanquest,Fix-it,or anything else that you know was part of that program,and uncheck the box or boxes.Click apply,and then you have the option to restart your machine right then,or restart later.That's your choice,but if it's really annoying to have the pop-up I'd restart now.
The onle difference with Windows 7 is that when you open Start you're already active in the "action" box,there's no Run box.
Let me know what happens,I'll keep trying if that doesn't work.
Good or bad,please rate my post?
Thanks
Bob
Posted on Aug 11, 2010
Avinquest uninstalls and reinstalls repeatewdly, but does not launch. What shall I do to cause it to launch. Microsoft fix it utilities was started after that and is still running.
Sounds as though you are missing an "exe." command or file; which is something too complicated to answer here. Since you are trying to install a utilities program, you should know what an uninstall manager program is. Find one of these free uninstallers and download it and it will remove the Avanquest from your computer. At this point, that would be the easiest solution. You can then download Glary Utilities Pro as the recommended replacement to the Avanquest; GUP will then take care of everything for you with a minimum of effort. Trust me.
Aug 27, 2014 | Avanquest Fix-It Utilities 8 Professional:...
Program
Fix-It Utilities is a program by Avanquest that is marketed as an all-around computer protection and enhancement tool.
Fix-It Utilities scans your computer for potential problems and fixes them automatically. Additionally, it monitors your computer in real time to alert you about hardware and software issues before they can cripple your computer.
If you are looking for a utility to handle your computer maintenance for you, Fix-It Utilities is one program that you might consider selecting.
Double-click the downloaded program file if you purchased the digital version of Fix-It Utilities directly from Avanquest.
If you purchased the boxed retail edition, insert the installation disc and allow a moment for the Fix-It Utilities installation program to load.
Click "Next" when the Fix-It Utilities Installation Wizard appears.
Read the terms of the Avanquest license agreement carefully before continuing.
If you are willing to abide by the terms, click the "Accept" button to continue.
Enter the name that you would like to register Fix-It Utilities under, and then type your 24-character product key exactly as it is shown in the product packaging or the email sent by Avanquest when you purchased Fix-It Utilities online.
Click "Next."
Select the radio button labeled "Complete" to install all of the features of Fix-It Utilities, and then click "Next" twice.
The installation utility begins copying the files for Fix-It Utilities to the hard drive.
When this process is complete, the installation utility displays a screen with four check boxes.
Use the four check boxes on the screen to indicate whether you would like Fix-It Utilities to check for and install updates automatically, whether you would like the program to make snapshots of your system for recovery in the event of a problem, whether you would like the program to monitor your computer for malware and viruses and whether you would like the program to scan your email.
Click "Next," and then click "OK" and "Finish."
Fix-It Utilities is installed.
If you used the check box to configure Fix-It Utilities to check for updates automatically, the program begins scanning the Internet for updates immediately.
http://www.avanquest.com/USA/software/fixit-utilities-9-professional-114420?gclid=COGnn7CYvZ0CFQgtawodB3Hjpw
if you still have no luck there are freeware alternatives on the internet as well as the chkdsk utility.
You could run the chkdsk disk utility
Click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your Hard Drive.
or an easier way to run the chkdsk utility
Windows 7 chkdsk
http://www.w7forums.com/use-chkdsk-check-disk-t448.html
Click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now, start should schedule this task when restart
have no input while the chkdsk utility is in progress any input may further damage your computers Operating System and Hard Drive
http://download.cnet.com/jetclean/3000-18512_4-75627788.html
JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again.
Optimizers and Diagnostics.
http://download.cnet.com/360amigo-system-speedup-free/3000-18512_4-75206713.html Improve your PC performance and fix errors.
May 25, 2013 | Avanquest Fix-It Utilities 9 Professional...
How to remove avanquest
Download, install and run Revo uninstaller and let it remove it for you. It's awesome, simple to use, and it's FREE. You can get it here:
http://majorgeeks.com/Revo_Uninstaller_d5706.html
Aug 20, 2012 | Avanquest Fix-It Utilities 11 Professional...
Fix it 11 will not uninstall
it is stuck in the registry to remove it go under start, run, tupe in regedit and hit ok. Do a searf for either avanquest or fix it pu pessing ctrland the "f" key at teh same time. once you find it you should be able to diable it and then unistall it normally. If not try removing it's folder from under the program files folder on the C drive.
Jul 01, 2011 | Avanquest Fix-It Utilities 11 Professional...
When trying to install FIx It Utilities 10 Pro I get a 'Fatal Error'message that says 'Installation ended prematurely becasue of an error. I have tried diabaling all Firewalls and virus checkers and even...
Do you had all
System Requirements
  • Windows® XP, Vista® (32-bit or 64-bit) or Windows 7 (32-bit or 64-bit)
  • Internet connection required for product updates and registration
  • Internet Explorer 5 or later.
Dec 05, 2010 | Avanquest Fix-It Utilities 10...
I purchased a copy of fix-it 10 professional and have not been able to get my computer to download the program. It keeps telling me that I have to locate fix-it 8, remove it before I can download the...
Boot in safe mode, search the entire hard disk for Avanquest or Fix-it files and folders and manually delete them. Then boot normally and remove the Fix-it 8 entry from the Add/Remove Programs list using this
http://www.gaijin.at/en/dluic.php
Finally run a good registry cleaner like
http://www.eusing.com/free_registry_cleaner/registry_cleaner.htm
After that you will be able to install your new program.
Sep 02, 2010 | Avanquest Fix-It Utilities 10...
Tried everything to uninstall Avanquest Fit-It
Go into the the Program Files directory of your C drive. Look for Avanquest or Fix-It directory. Look for unwise.exe or uninstall.exe or something similar. Double click that and follow the prompts. If that doesn't work, please let me know and I'll do some more research.
Feb 16, 2010 | Avanquest Fix-It Utilities 9 Professional...
How do i remove avanquest fix it
When the question is so specific, for sure, the user is not being able to remove it using the control panel. It would be great to ASK if they already tried such SIMPLE solution. Fix-it is a pain to be removed, specially the version 10 that won't be removed even with the Revo uninstaller! I'm working on 2 computers to remove this piece of s....ware and will post any solution I find for it.
Nov 27, 2009 | Avanquest Fix-It Utilities 8 Professional:...
Avanquest Fix-It Utilities 8 Professional: Windows Logo
370 people viewed this question
Top Avanquest Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Sheldon Dedek
Bill Boyd
Are you an Avanquest Computer and Internet Expert? Answer questions, earn points and help others
