SOURCE: Lost manual need cleaning instructions
You can download the operating manual for your machine in pdf format right to your computer from www.bunn.com By the way, I wouldn't personally put vinigar in any Bunn machine, as it takes forever to run enough water through them to get rid of the vinigar taste.
SOURCE: Self Clean Button
Unplug the coffeemaker for 1 hour or longer - it should reset the coffee maker and get rid of that self-clean light.
-Tha Mp3 doctor
SOURCE: clean light will not off after cleaning cycle performed 4 times
Unplug the machine for 20 minutes or longer - don't skimp on the amount of time, or it won't work. After 20 minutes, plug the coffeemaker back in, and you will see that the self-clean light is now off.
SOURCE: Quisinart DCC 1100 Series Coffeemaker
this solution is mostly right - in my opinion you should pull out the filter casing altogether and run the cleaning cycle without it in there, just wash that separately in the sink. Then when the cycle is done, you can put it back in with a new water filter in the casing. That filter casing seems to stop the machine from knowing it is clean.
SOURCE: Can't find instructions for cleaning
You can buy commercial coffee maker cleaner at most places that sell coffee makers. Follow the package directions. Usually you just add it to a pot of water and run it through. Repeat the process, then run a couple of pots of plain water to rinse it. You can also use a pot of plain vinegar to clean the machine, but its a smell that many people find unpleasant.
