Question about Sony VAIO VGN-FS760 Notebook
Fuction key operation in windows vitsa - Sony VAIO VGN-FS760 Notebook
Posted by mrbeach95662 on
Anonymous
    New Friend:
    Problem Solver:
  • 6 Answers
Have you done a clean install of vista? If so you are most likely missing a driver for your laptop...the driver that enable the function (fn) key to work is called Vaio Event Service
Download and install this http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNFS760W&upd_id=2287&os_id=7
Posted on Aug 11, 2010
I am not able to get the the start menu black screen ?
Your windows operating system is currupted. Try press f8 after posting screen if that works, and go into safe mode and go from there on. If your operating system doesn't prompt safe mode screen or anything after that... then your windows is corrupted and needs repair or restore. With some Hp computer, restore/repair option is in a hidden partition and you can recover this method at the hp logo via a F fuction key prompting to press for recover/setup/repair. Follow instruction and it should help you out. If there isn't that option, then your kind of out of luck, and a full windows installation is required.
Jan 30, 2011 | HP Pavilion 533c (P9939AR#ABA) PC Desktop
Window on driver side will not go down
Tries pushes the button said lock/unlock windows a few times,see if that work.Not.Read ur car owner manual find out which the fuse belong to the automatic windows fuctions.Check ur fuses box under the car,near the engine pull up hook opener lever.If the fuse is not dead.The motor that operate the driver side window pully lines to operate automatic windows is dead.Require changing the motor.
Sep 24, 2010 | 1989 Ford F 150
I bought a lenovo ideapad y330 laptop one year ago.windows vista home premium,service pack 1 is installed there but they didn't given me any dvd. now my windows files are currupted. how can i get a...
Without a recovery disk, you have a big problem. The Vista Key is locked to Lenovo so you need a Lenovo Vista CD.
You could screw around and hope that you get something out of Lenovo to fix your problem but I would seriously look at installing Windows 7 Home Professional. It is much better than Vista. With 2GB you should be OK, but more memory wouldn't hurt.
Aug 04, 2010 | Computers & Internet
What are the basic applications that runs on Windows XP O/S?
well every application and software is built on on a platform that is compatiable with some certain operating system . u should have encounter some applications that run well in xp and vitsa but are not compatiable with win 9X and others . win xp also introduce a option of compatibility for applications . just right click a .exe file and go to properties there u will find some options . suppose if u have some application or software which were runing fine in win 9x and 2000 but seem not to work in win xp u can set option from compatibility than how the system should run the application and in what platform . if u choose win9x/2000 option the o/s will trick the software that actually its runing on win98/2000 . but it works in some cases . i hope u understand thankx and take care of urself
Jun 11, 2009 | Microsoft Windows XP Professional for PC
One key recovry
To assist you in creating Restore Point or using the System Restore of Windows Vista, please refer to the link below for a step by step instructions:
http://www.vista4beginners.com/System-Restore
Jun 06, 2009 | Microsoft Windows Vista Ultimate Edition
Laptop with no o/s
Load an OS into it if it has an operating key the operating system that it came with should work. It looks like that particular model comes with Windows Vista Ultimate 64-bit with Service Pack 1. You will need to get that installed on it for it to work with the operating key. Otherwise use any other operating system you want.
Jan 30, 2009 | Microsoft Windows Vista Ultimate Edition
Driver
how can i get driver to see in computer?
Nov 17, 2008 | Video Cameras
Software
Some how you have user account setup incorrectly. Go to Start, Control Panel, User Accounts, User Accounts and change Account Type. That should solve your problems.
Nov 10, 2007 | Microsoft Windows Vista Ultimate Edition
Benq Joybook 3000 Keyboard Issues
There are several extra function keys on your laptop. Something like "Fn" is common to most of the notebooks, and is used to control secondary fuction of a key. You will see keys marked with other than the ordinary alphabetic letters. These are the secondary fuctions. The purpose of all the secondary keys are explained in the manual that accompanies your laptop. you may have pressed a key combination unknowingly as a result you see this problem. Pressing the same combination will revert it back to normal operation. You should also check the key contacts are free from dust and other particles. If some thing like milk or water is spilt on it, then it is normal to get these problems, ultil it is cleaned.
Sep 26, 2007 | BenQ Joybook 3000-01 Notebook
Sony VAIO VGN-FS760 Notebook Logo
145 people viewed this question
Top Sony Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
Muntejaya Ginting
Muntejaya Ginting
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
