Question about Beverly Hills Polo Club Dress #52012 Watch for Men
I bumped and chipped the crystal. Is it possible to have a new crystal sent to me?
Posted by yinglingwh34 on
Michael C. De Vito
    Genius:
  • 1,970 Answers
Mcdevito75 here, That may depend on the watch and the maker of your watch, as sometimes a new crystal is only available thru the watch manufacturer, if so, the watch manufacturer may want to install the new crystal themselves. If your crystal is made by an after market company then yes you could get a new crystal sent to you. Look for a small watch repair shop in your area to find out for sure.
Posted on Aug 11, 2010
Replace crystal casio wva-430
Possibly, Check with a jeweler who still does watch repair, or if there is a clock shop nearby.
Time/labor and availability and cost of the crystal are what will affect the final price, but skilled watchmakers can have it done in barely more than a few minutes.
Jul 05, 2012 | Casio WVA430A-1AV Wrist Watch
I have a EH-23GA Gold E Howard watch that I purchased from Amazon.Com 5/16/11. While working on my lawn mower I must have bumped the crystal on something. It chipped a flake off the inside at about 2...
you can get the crystal off, but not back on. There is a special tool that is used to compress the crystal to make it fit in the bezel. Besides, if a piece chipped off, it is no longer waterproof. Take it to a jeweler and he can put a new crystal on in no time. Crystals are not expensive.
Nov 02, 2017 | La Crosse Technology E. Howard Ambassador...
I HAVE A CHIPPED CRYSTAL (GLASS FACING). WHERE CAN I GET A REPLACEMENT AND/OR HAVE THE CHIPPED CRYSTAL REPLACED?
Here is a link to the fossil website's policies on repair. http://www.fossilcanada.ca/webapp/wcs/stores/servlet/ContentView?langId=-1&storeId=32563&catalogId=20509&page=warrantyRepairs
If your watch is not in warranty you may have to pay for the repair. Send your watch to fossil at the address listed on their website and follow their guidelines by including a description of the problem and other necessary information.
For a solution that may be faster, you could try taking the watch to a local jeweler to see they can repair it. This is unlikely though, because the may not have the crystal to repair it.That is worth a try though. At the very worst, you will have to send the watch to fossil for a repair.
Jul 21, 2011 | Fossil Anadigi JR9121 Watch
I have a Police Phalanx watch, black and rose gold effect. The glass has a couple of scratches and one of the rose gold markers has come away at the 10 o'clock position. Would it be expensive to repair...
If the crystal of your watch is made of plastic, it may be possible to buff (or pay a jeweler to buff) it. Buffing a crystal is very inexpensive--sometimes free--and may eliminate the scratch, or, at the very least, greatly reduce its prominence. However, glass crystals cannot be polished in this way; the only way to fix chips or scratches is to replace the crystal, which can run anywhere from $15-50+, depending on the type of crystal and amount of work required to replace it and test for proper water resistance. Replacing the mineral glass crystals on some diving watches can be very expensive.
Markers on a watch dial are ordinarily stuck on with little pins and/or a dab of adhesive. If the detached marker is still in the watch, this is ordinarily a fairly simple repair. The watch would be opened and the movement removed. Next, the jeweler would carefully place the marker back into position, probably adding a tiny drop of glue to keep it in place. A job like this can cost as little as $25, if it requires no replacement parts and you take your watch to a place that does a lot of watch repairs, as opposed to a general jewelry store that has to outsource the repair to a wholesale workshop.
May 06, 2011 | Police Phalanx Watch 11599JS 02 m Watch...
I need change the glass.where?
It is possible for jewelers to order exact fit replacement crystals for many watches. However, generic replacements are not made for all watches. If your jeweler cannot perform this service (which may cost as little as $10 for common crystals), ask if the jeweler knows of a jeweler's specialty business that can custom-fit crystals. These small shops custom-grind crystals from blank stock and hand-fit them to your watch. Such companies used to be relatively common; today, most conduct operations via mail-order or exist in large cities like New York where there is enough local wholesale and walk-in business.
Department stores and chain jewelry stores rarely have the on-sight resources to service a broad selection of watch crystals. Seek out an independent jeweler or one that has a "we repair watches" sign displayed.
May 06, 2011 | Cerruti Genova Swiss #CT69051X403021 Watch...
How do you remove the cyrstal
Thanks for contacting FIxYa.
Is there a reason you want to remove the crystal? Is it broke?
If the crystal is broke, it can be sent to Citizen. Here is a link for you.
http://citizenfactoryservice.com/
Best regards. Jewel
Sep 13, 2010 | Citizen Bracelet Quartz Watch
I have cracked the face of my Pulsar watch. Is it possible to buy a replacement and where from?
Thank you for contacting FixYa.
Most crystals can be replaced by any local watchmaker who cuts their own crystals. You can look up a local watchmaker to see if they can do it. If its a specialty type crystal, it can be sent to Coserv, the repair center for Seiko/Pulsar.
You can contact here:
http://www.pulsarwatches.com/home2.asp#Contact_PULSAR
Best regards. Jewel
Aug 31, 2010 | Watches
I have a man's gold 52250 with SR626SW battery about a year old. I bumped it and chipped the crystal. Is it possible to get a new crystal? I have a local place that does all my batteries and bands that...
Most watch warranties do not cover crystals of course, so my best answer to you is to take to local repair. But the following link is access to BPC if you would like to try to find out from them their policy and such. Good luck
http://www.bhpc.com/contact/
Aug 11, 2010 | Beverly Hills Polo Club Watches
My watch has a chip in the crystal - who can put a
Chip in crystal is not repairable. You need a new crystal. No need to send the watch away, as any local watch repair shop can do this.
Rate me, plz.
Jan 13, 2010 | Timex 27191 Wristwatch
Hello my name is James nd i receive a kenneth cole watch for christmas from my daughter and second time wearing i accidently chip the lense and scratch on a wall can i send it in for repair and where
I suggest finding a watch specialty store.  Many jewelers can also change the crystal for you if they have a watch specialist on site.  If the crystal is round most stores can do it on site.  If it is not round, it usually has to be shaped and must be sent out.  Retailers such as Precision Time can change a round crystal, on site, for less than $40.  Go to precisiontimeco.com for locations.  If it is not round, they can also send it to their service center for a new crystal.
Jan 19, 2009 | Watches
Beverly Hills Polo Club Dress #52012 Watch for Men Logo
250 people viewed this question
Top Beverly Hills Polo Club Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Beverly Hills Polo Club Watch Expert? Answer questions, earn points and help others
