Most cases the harddrive is faulty if with code the PSA+ 2000-0151 code means Hard Drive (d): - Incorrect status: (x) (s) etc...Caution:Remove any and all power sources Including but not limited to: AC Adapter, Battery, or Desktop Power Cord, before you remove or reinstall an item in your computer." So Run the Drive Self Test (DST) from the Utility Partition also known as the 32 bit diagnostics to determine if the previous error has been corrected. If the DST from the Utility Partition does not indicate a failure of the drive, we consider the error to have been corrected and the drive does not need to be replaced.
SOURCE: in my dell desktop optiplex 330 hard disk is
Is it a BIOS password or a HDD password? If it's sewt in BIOS, you could try to reset the BIOS to factory default (which should remove any BIOS passwords) If however it is a HDD password, it is a bit different.. you may need to restore your sytem (low level, high level formats, then reload your OS sorry but you likely lose all your data..What OS do you use? there are programs that can possibly give you a boot cd depending on whether your system is fat32 or NT.. NT is more complicated because fat32 will not read NT BUT NT will read fat32.. IF you have the ability to restore your OS then first try to do a complete restore with backup.. that way you may be able to save most of your datafiles.. if you have never accessesd the pc then just try a destructive system restore (will low-level, then high-level format the HDD and reinstall your software without any SW passwords..
First thing I would try is to get into the BIOS and unset any passwords there.. If you need more help you can try to contact me [email protected] with more information
SOURCE: Dell Dimension 3000 reformat trouble
please re partition the hard disk and install the operating system. if the same error continues then change the ram and try
SOURCE: Dell OptiPlex GX150 won't do anything.
try going to the bios by pressing f2 or delete key on the keyboard at the dell logo.
if you are able to enter the system setup screen, reset the bios.
to reset the bios, press num lock, caps lock and scroll lock so that all 3 lights on the keyboard are on.
press alt + e and alt + f keys.
press esc twice
then select save changes and exit.
also try booting through the safe mode by hiiting f8 on the dell logo.
you can also try booting through the dell resource cd or win xp cd.
SOURCE: Dell Optiplex 170L does not recognise an 80GB Hard Drive
I have the same problem. With SATA it boots perfectly, but on a IDE it fails.
SOURCE: Enquiries on maximum supported hard disk capacity and memory
Dell Optiplex 760 Vista
Max CPU Intel Q9550
Max RAM 8GB RAM
Largest HDD Shipped 1TB (Will likely Support 2TB)
Optiplex GX260
Max Intel Northwood 2.53 GHz - 533
Max RAM 2GB
Largest HDD Shipped was 200GB (Will likely support 500GB)
Dell Dimension XPS D300
Max CPU 333 Pentium II
Max RAM 384MB
Largest HDD Shipped 16GB (Will likely Support up to 80GB)
Dell Dimension XPS M
Max CPU 166S
Max RAM 64 MB
Largest HDD Shipped 4.3 GB (Max HDD likely 20GB)
