If it is an older computer, the motherboard may not accept an XP installation. I have older desktops that will not accept an XP install but work fine with Win 98 and ME.
If newer model the problem could be with the disk or the cd reader. A defect in either will prevent an install.
The Magical Jelly Bean Keyfinder is a freeware utility that retrieves your Product Key (cd key) used to install windows from your registry. It has the options to copy the key to clipboard, save it to a text file, or print it for safekeeping. It works on Windows 95, 98, ME, NT4, 2000, XP, Server 2003, Windows Vista, Office 97, Office XP, and Office 2003. Please rate this solution. Regards.
you have to use xp os.because windows 98 is tatally back dated. thats why its not opening. or you can check it into another xp os. computer if it is open then your sure that windows 98 is not supporting, or if it is not open then your pendrive has some problem.
That shouldn't be a problem you just have to run the setup..Infact i am using..Let me know if you are running into any problems during support so that i can help you out..
sir u have to install drivers of flash drive in win98 (the cd which u got with flash drive )coz xp is plug&play so their is no need to install drivers in xp try it good luck
Try using nLite or XPLite to slim down your XP footprint. Turn off all the GUI chrome and go back to the Windows Classic theme. You should have no trouble getting XP lean and mean enough to run happily in 256MB, even with large office apps.
If that fails, consider 2k. Reason being, most modern hardware doesn't come with 98 drivers, but 2k is similar enough to XP that most drivers will work with both. Also, there are no security updates being provided for 98 any more.
If you're still dead-set on 98 as the solution, please clarify your request for "DLLs".
