Question about Lenovo ThinkPad R60 Notebook
Scrolling not working - Lenovo ThinkPad R60 Notebook
Posted by lovely_dhill on
Suuny Kohn
  • 808 Answers
Reset ur CMOS will fix ur problem or use reginout regcleaner Best of luck
Posted on Aug 11, 2010
  • bamaka Sep 24, 2010
    how do u do that
The scrolling on my msi netbook's trackpad isn't working, I keep sliding up and down the right side of the trackpad but nothing happens?
On the msi netbooks to scroll it doesn't work like most of the other netbook trackpads. The scrolling feature works like arrow buttons, you have to tap the top right corner to scroll up, or the bottom right corner to scroll down. It takes getting used to.
Sep 30, 2013 | Computers & Internet
Scroll bar
Most modern laptops with touchpads offer vertical scrolling, horizontal scrolling or both. These features are located along the right-hand and bottom edges of the touchpad, respectively, and are activated when you swipe your finger along the touchpad edge. Scrolling functionality is nearly always enabled by default, but some users find the feature an annoyance and elect to turn it off. In most cases you can simply turn the feature back on using the Windows Control Panel.
Click the Windows Start button, select "Settings," and then click "Control Panel." Double-click the icon labeled "Mouse." Select the Touchpad properties tab. The labeling of this tab varies, depending on your computer manufacturer, operating system version and the device drivers installed on your machine. Common labels include "Touch Pad," "Device Settings" and "Dell Touchpad." If you do not see this option, you may not be able to turn on scrolling for your laptop; skip the remaining steps and refer to the "Warnings" section below. Click the "Settings" button within the Touchpad Properties menu and look for the section labeled "Scrolling Settings" or similar. Enable scrolling within this section and define other scroll settings, such as scroll zone width and scrolling speed. Click "OK" to confirm your changes, and then close the Control Panel windows opened in the previous steps. The scrollbar on your laptop is now enabled.
Scroll Is Not Working With Windows 7 b> Certain computer touchpads have a vertical section on the pad itself that is used to scroll through the page or program window that you are currently viewing on your computer. If the scroll functionality suddenly stops working but the actual touchpad is still fine, this means that the part of the software for the device that controls the ability to use the scroll has been disabled. You can enable it again in the Control Panel.
Click "Start." Click "Control Panel." Click "Mouse." Select the "Enable Scroll" option (or whatever similarly named option is available on your specific model of laptop computer). Click "Apply." The scroll bar on your touchpad will now work again.
Feb 03, 2013 | Acer Aspire Computers & Internet
HP 2530p EliteBook - touchpad stopped working. Scrolling works except touch scrolling on right side of pad) and right button, but that's all. Wireless mouse works fine.
To access Mouse Properties, select Start - Control Panel - Hardware and Sound -Mouse.
Use Mouse Properties in Windows to customize settings for pointing devices, such as button configuration, click speed, and pointer options.
Jan 18, 2013 | HP EliteBook 2530p Notebook
Asus ul30a scroll not working
Visit the link to view detailed information on troubleshooting the scrolling feature.
Scroll
May 27, 2012 | ASUS Computers & Internet
Scroll pad not working on hp laptop mouse still works though
Need to enable Scroll function on the notebook.
Scrolling function is not working:
  1. The scroll function may stop working if the scrolling feature is disabled in Mouse Properties. To enable the scroll function, follow the steps below.
  1. Click Start , Control Panel . Select Classic View from the left side of the Control Panel window.
  1. Double-click Mouse in Control Panel, and then select the Device Settings tab in the Mouse Properties window.
  1. Click Settings , Virtual Scrolling . Select the boxes labeled Enable vertical scrolling and Enable horizontal scrolling .
  1. Click OK to save and exit the Mouse Properties window.
  1. After changing these settings, the scroll function on the touchpad will be enabled.
Jul 24, 2010 | HP Pavilion dv5000t Notebook
Scroller goes up when scrolling down
This works for all mice.
click the scroll button and movie it up and down for a while and it will work just fine.
i had the same problem with my acer mouse but when i looked at a forum for the mac os x mouse someone said this tip and it worked
Oct 27, 2008 | Dell U0636 Mouse
Mouse scroll wheel doesn't work properly
have you tried clicking on the bar that moves the page left to right and then tried using the scroll wheel?
Sep 19, 2008 | Microsoft Wireless IntelliMouse Explorer
Scroll lock in excel 2007
When SCROLL LOCK is on, "SCRL" appears on the Excel status bar. If you press the arrow keys when SCROLL LOCK is on, you scroll one row up or one row down. Or, you scroll one column to the left or one column to the right. To use the arrow keys to move between cells, you must turn SCROLL LOCK off.
Sep 18, 2008 | Microsoft Office Professional 2007 Full...
Scroll ring intermittent / non functioal
I have a similar symptom, that is, apparent loss of scroll ring functionality as homercles1 noted, but in fact the scroll ring functionality gets toggled between horizontal scrolling and vertical scrolling as Rithas has noted. A window that is not wide enough to require horizontal scrolling will give the appearance of loss of scroll ring functionality when the scroll ring is in horizontal scroll mode. Likewise, a window that is not tall enough to require vertical scrolling will give the appearance of loss of scroll ring functionality when the scroll ring is in vertical scroll mode.
Solution that worked for me:
My upper right-hand button is defined as "Allow Horizontal Scroll" and by clicking this button, the scroll ring function toggles between horizontal and vertical scrolling. In fact, what can appear to be a nonfunctional scroll ring in some windows is very useful when moving around in large windows.
Hope this comment will be useful to you.
Nov 20, 2007 | Kensington K64325 Trackball
Hot key
for mine it's:
tap scroll lock twice then press 1 or 2
Sep 26, 2007 | Belkin F1DK102P 2-port KVM Switch
Lenovo ThinkPad R60 Notebook Logo
91 people viewed this question
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
