BenQ DC E610 Digital Camera Logo
Anonymous Posted on Aug 11, 2010
System error 0013, hit the camera 3-4 times with palm still encountered problem is there any solution what is the root cause and how to solve this ?
Samir Shah
Level 2:
Champion:
  • Expert 220 Answers
  • Posted on Oct 02, 2010
Samir  Shah
Expert
Level 2:
Champion:
Answers
220
Questions
Helped
127578
Points
356
Try the suggested solution, It works.
Samir
2answers
2helpful
System error 0013
This was solved by just Hitting it againsy my palm 2-3 times as suggested by one of the experts oeforum.
Samir
2helpful
2answers
System error 0013
This issue has to do with the lens doesn't come out, in front of the camera. Just hit the camera 3-4 times on your palm it will start working.
Service Pack problem
******************************************************************* VideoCam Suite 2.0 *******************************************************************
[Table of contents] 1. Notes about operating environment 2. Notes about operation
<><><> 1. Notes about operating environment <><><>
1. [Important] Adobe Acrobat(R) Reader 5.0 or later or Adobe(R) Reader(R) 7.0 or later is required to read the operation manual or the help information on your PC. Get the license for using the operation manual before reading it.
2. AC adapters are recommended when using a notebook PC or a HDD/SD video camera with the VideoCam Suite. If a battery pack is used to power the HDD/SD video camera or the notebook while recording or previewing motion pictures or still pictures, they may not be recorded, previewed, or copied to the PC Hard drive properly.
3. Standard configurations must be used for the fonts and screen settings for Windows(R). Depending on the settings, characters may not display properly.
4. It is impossible to use VideoCam Suite simultaneously with other motion picture editing software or video capture products. Note that this software may not function properly if software with a timer recording feature in the background is running.
5. This software will function properly only when the system time is set to a value within the following range. From 0:00 on January 1, 1970, to 23:59 on December 31, 2037 If the system time is set to a value outside the range listed above, the software may not start or function properly.
<><><> 2. Notes about operation <><><>
1. After installing/uninstalling the application, a dialog box is displayed notifying the user that the system needs to be restarted. Make sure to restart the system to complete the installation/uninstallation.
2. This software can handle only motion pictures and still pictures recorded by this software or the Panasonic video camera packed together with this software. This software cannot process motion pictures and still pictures recorded by any other video cameras, DVD recorders, software, commercial DVD video, or commercial BD video.
3. User privileges for this software - It can be used by only a user with administrative privileges for Windows(R) XP and Windows(R) 2000. - It cannot be used by the Guest users in Windows Vista(R)
4. While recording, if motion pictures cannot be recorded properly for any reason, follow the procedures described in the operation manual to restart the Windows system. Motion pictures may not be recorded properly if any other application software is used while recording the motion pictures. Close all other application software and any resident programs, such as virus scanning software. We recommend closing all other applications and resident programs, such as virus scanning programs, before starting this software. While recording motion pictures on a DVD disc/SD card do not execute the following operation since it may disturb proper recording and destroy the DVD disc/SD card. - Turn off or restart the PC or DVD/SD - Switch users or log-off - Change the screen settings - Use the power saving functions, such as the screen saver, sleep, standby, and pause. - Close this application by force
5. To record motion pictures on a DVD disc or an SD card, check that the motion pictures can be recorded properly. After checking that motion pictures are recorded properly, delete the original motion pictures from the PC Hard drive.
6. When the edited motion picture is output in MPEG-2 format, some scenes may not be generated completely in MPEG-2, and some parts of frames may be shifted or omitted.
7. When motion pictures are copied from a DVD-VR formatted DVD disc to the PC Hard drive, data other than motion pictures cannot be copied.
8. Do not modify or delete any files or folders related to this software. Otherwise, the software may not function properly.
9. This software can only process DVD-Video discs recorded by this software. This software cannot properly process DVD-Video discs recorded by any other DVD authoring software.
10. This software cannot process motion pictures or DVD discs/SD cards that are copyright protected.
- Microsoft(R) and Windows(R) are registered trademarks of Microsoft Corporation in the United States and other countries. - All names, company names, and product names used in this document are the trademarks or the registered trademarks of their respective companies.
1helpful
Fawabi
0013 indicates that your camera has a hardware (related to Lens) defect.When dirt gets into the lens mechanism the lens wont retract properly.. You wont believe what i have suggested for a similar problem and it worked! Its a similar lens stuck error..
http://www.fixya.com/support/t240817-camera_error_e45
2helpful
2answers
System error 0013
I have a digital camera Benq dc E610, it showing error 0013 while switching on.
33helpful
13answers
System error 0013 benq DC E610 DIGITAL CAMERA
i had the same problem but now i have solved it.........its not a software problem..... the lens in fornt of the camera is not able to come out......just hit the camera 3-4 times on a table it will start working.......hope your problem is solved
Showing system error 0013
DAMM i have the same problem after i dropped my camera.
Can someone pleaseee help !!!!! Im crying right now literally i need my camera back !
1helpful
3answers
Reinsert tape message
I got the dreaded reinsert tape message today and i thouht that my video taping days were over. i then made my way to this page and saw this. whack it three or four times and it will work. at first i thought what a load of crap but i tried it anyways... being really mad at the time, i showed my camera no mercy. i took out the tape and gave it 4 hard hits with my palm, put the tape back in and it worked. thanks alot, this works
i
Top BenQ Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Eric
ADMIN Eric
Tony Parsons
Tony Parsons
Are you a BenQ Camera Expert? Answer questions, earn points and help others
