Question about Kenwood KM010 Food Processor
The part which lifts up and down will not click down into place and has to be held manually down to mix bread etc
Posted by kate_hughes7 on
Unable to download Rhondo 2500 manual
the four pronged tool is a dough hook. Use this for kneading/mixing heavy dough, such as: white bread dough, pastry, etc.
Dec 19, 2013 | Food Processors
Kenwood BM450 power cutting out
sounds like its overheat sensor.... keep it on wide open counter and not in a corner or by wall under a cabinet
Sep 08, 2013 | Food Processors
Does anyone tried 'The food lovers fat loss system' ,? Is it effective or not? Please share your experience
None of them work!
Cut out Dairy products (cheese, ice cream, etc) and bread and cakes and eat only small portions of good food!
NO! Not McDonalds or Burger King either!
Oct 16, 2012 | Food Processors
I can't figure out how to use it.. I just want to make a smoothie!
You can get a manual at WWW. euro-pro.com.
In order to use the blender the food processor bowl and lid must be LOCKED in place. Turn the lid on processor until it's locked. Then you are ready to use the blender. Select desired speed or pulse.
In order to use the processor, remove the blender and place the gray lid in its place. It should be locked. The lid keeps the blender shaft from spinning and allows the shaft on the processor to turn.
To remove the processor bowl, gently lift up on the lid to unlock it and then turn it away from processor. Bowl lifts off. That's it! Enjoy!
Hope I have been of some help to you.
Feb 10, 2011 | Bravetti Platinum Pro Quad-Blade Food...
I can't get the food bowl off the processing unit. i have removed the cover as the manual says. I have left the blade in as the manual says. The picture looks as thought you should just lift it...
On page 8 of the manual that I will give you the link to: leave the cover in place on the container. Use the cover to help remove the container. Rotate the cover clockwise 180 degrees until the two tabs on the cover meet the two container tabs. Continue to turn the cover, but do not press down as you turn, using your thumb against the tabs until the container is released. Empty the remaining food from the container.
http://kitchen.manualsonline.com/mdownloads/c44fa16e-225f-49e2-84e5-348ee18b9c1b.pdf
Jul 15, 2010 | Sunbeam 4817 Oskar Food Processor
We need times for cooking bread recipes as the bread recipe we use has no timing and the bread is flat and hard and dry.
some times / hard and dry problems relate to mixture . more mosture . ( liquid's ) needed in mix .. time / tempt/ and altude . / all things needed for good baking . google your bread and type . as there is much info for this .. **** ..
Jan 10, 2010 | Food Processors
When i try using it, nothing happens. i cannot
Remove the work bowl, blades, etc from off the base.
Plug the processor in and press the ON pedal down.
Use a pen to press in the rubber button on top of the base - you should hear a sound.
Now reassemble the bowl - lock the bowl in so that the handle faces front; insert blade of choice; place the tab under the feed tube of lid slightly left of center of the work bowl handle and slide the lid counter-clockwise until it clicks into place; insert pusher and make sure it locks into place.
You should be good to go again.
Sep 30, 2009 | Cuisinart Food Processors
Instructions for the food processor of my Cuisinart Duet
Place the gearbox on top of the blender/food processor
Place the work bowl over the spindle, with the handle facing the front of the machine - make sure the tabs lock into place.
Place the stem adapter on top of the spindle, then the blade.
Place the lid on top of the bowl, with the feed tube facing the back of the food processor. Then the pusher into the feed tube.
Here is the link to the user manual with visuals 9p.6 is most helpful):
http://www.cuisinart.com/share/man/10_man.pdf
-Tha Mp3 Doctor
Mar 23, 2009 | Cuisinart BFP-703 SmartPower Duet Food...
Robot Coupe clicks, runs 5 seconds, stops for 30 seconds, clicks, runs 5 seconds...
The clicking noise is an internal circuit breaker or motor protector. These things are not made to be bogged down or overfed. The motor is heating up & tripping the overload, after cooloing it resets. Time to buy a new one or get the motor replaced ($600-$800)
Oct 29, 2007 | Robot Coupe R100 10 Cups Food Processor
Kenwood KM010 Food Processor Logo
75 people viewed this question
Top Kenwood Food Processors Experts
Ross Keen
Andrew Taylor
Andrew Taylor
Are you a Kenwood Food Processor Expert? Answer questions, earn points and help others
