Need operating manual for a/c model 40BNE024301 serial number 2105V08300 with wireless digital remote control model TAC490
Posted by cathysbooks on
Daniel Malchi
Hi, I finally found a remote for this AC!!!
here is the link https://remotesremade.com/products/replacement-remote-for-carrier-model-40bne
Posted on Jul 14, 2020
5 Related Answers
Anonymous
SOURCE: Need manual for remote control
I need manual for cl015 also...
Posted on Oct 26, 2008
Anonymous
SOURCE: singer electronic control sewing machine model number 4562
http://www.singerco.com/accessories/
You can download the instruction manual for free instantly.  Or pay $15 for a hard copy.  Some attachments are available for purchase on the website, others you can purchase at JoAnn Fabrics.  Good Luck.
Posted on Nov 29, 2008
Anonymous
  • 6 Answers
SOURCE: Need 5 Digit Remote Code for a Panasonic Receiver HE-100
Try 1518 or 1039
/www.comcast.com/remotes/universal.html
Posted on Dec 12, 2008
Anonymous
  • 17 Answers
SOURCE: Need manual with directions on how to use the
1-800-295-4448
Posted on Feb 10, 2010
award462
Anthony Ward
  • 397 Answers
SOURCE: chef gas oven user manuals
http://www.fixya.com/support/r4964670-get_manual_most_any_electronic_device
Posted on Jun 03, 2010
HOW TO CHANGE THE TEMP. FROM celsius TO Fahrenheit IN TAC490 VER 1.1 AIR CONDITIONER REMOTE CONTROL
Dear Fuad,
You will need to contact the manufacturer of the remote control. Unfortunately, we do not have any information to help you with.
Use the search engine of your computer to find the manufacturer, God bless your efforts,
Jun 25, 2018 | Heating & Cooling
Need an English user manual for our Tadiran TAC490 air conditioning remote
Try Googling (tadiran)(TAC490)(manual) without pares. You may have to refine your search to get a version in English.
May 03, 2018 | Heating & Cooling
Total Control Universal Remote. URC 4140. What is the 4 digit code to operate the above TV
Search Results
    [PDF]Total Control URC-4140 - Universal Remote Control Codes
    www.remotecodelist.com/remotes/URC_4140_B00_and_B01.pdf
    UNIVERSAL. Remote control. URC - 4140 ... Your TOTAL CONTROL can operate four devices: a Television, ... The TV, VCR/DVD, SAT and AUX keys select the device.... 4. Enter your four-digit code using the number keys. The red light will blink twice.... To set up your other devices, follow the same instructions above, only.
    Codes and links for a number of universal remote controls, including Sony, RCA, ... GE Remote Codes, General instructions for GE Universal 3 and 4 digit remote controls. ... This manual may work for a number of Philips-Magnavox remotes. ... Total Control URC-4140, PDF Instruction Manual (remote also known as Crest .
Jan 13, 2016 | Sanyo 42 in. LCD TV
Do you have a manual for LG Remote Control 6711A20067E
Go online to LG HQ, quote your model number/serial number and you may be able to down load a manual. If not search the web with that model number or an aircon repairer who may have a soft copy.
My first stop would be EBAY with that model number.
May 20, 2014 | LG Heating & Cooling
I want to program this remote to control my emerson tv
Download a PDF manual of the remote based on its model information. Use the serial number on Google if you don't have the model number handy. You can use Barcode scanner or Goggles for Android, or a similar app on other devices.
Oct 26, 2013 | RCA Remote Control DTA800
Someone gave me a Philips TV, but it doesn't have a remote. I have the serial and model number. They are 94492161serial #, model # is PL7125C107. Is it possible to purchase a remote for it?
Hello
Just buy one PHILIPS UNIVERSAL REMOTE CONTROL MODEL NUMBER [CL 034]. Philips is listed in its codes. Serial number and model number isn't mind. There are so manu codes for you to set it up. Code for philips listed is :
........... 0807 0022 0020 0422
................. 0122 0222 0322 0002 0520
....... 0919 0521 0621 0430 0247 0901
....... 0402 0408 0109 0210 0310 0715
You will get its catelogue and user manual with details along with that device.
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
OK.
Feb 24, 2011 | Philips Televison & Video
I have a remote contorl universal philips .i'm tring to makc my citezen tv work lost instruction manual serial numb 50804225
You don't need the serial number, yo need to look for the model. Once you have it, here are most of the manuals for Philips remotes.
Aug 24, 2009 | Philips Prestigo SRU8008 - Universal...
Need code
The Codes For Sharp Are 0093,0688,0165,0039,0386,0157
Hope This Helps.
Jan 04, 2009 | One For All URC-4330 Remote Control
Cable ez 2.4ghz wireless catv sender
I have a Cable EZ remote with the instructions o the back. See if this will help you (I wrote it below exactly as written on the remote):
Remote Control Description
How to set up the remote controller:
For first time to set RF controller ID Code
1. Press [SET] + [FUNCTION] together
2. Key in your personal code (3 digits 000-253)
3. Press [SET] again to finish
For CATV sender learning the remote controller ID
1. Plug the adapter into the CATV SENDER and wall outlet and the sender will power on automatically
2. Press [SET] + [POWER] in 10 seconds to set CATV SENDER ID code. It will show your personal code on the screen.
The remote has a label with the model number AWV351RC and an FCC ID of NGVAWV35XRC. Made in Taiwan.
Hope this helps. I am missing the operating manual that came with the unit, so if anyone has a copy you can scan and post, it would be appreciated.
Feb 08, 2008 | Televison & Video
217 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
