If you decide to replace bulb I suggest that you replace with the best quality bulb. I found the brightness between good and best bulb was significant. I have ordered from the internet and have had great results.
There are other possible causes of lost video. The bulb is only the most likely.
I need some information so that I can better answer your question. 1. Are you using direct cable from the wall, cable box, satellite?2. Please let me know what will be the display if you hit the menu button at the front panel or on the remote control. Jdvillanueva
Generally,
a DLP bulb lasts about 8,000 hours (if a TV is on 10 hours a day, every
day, the bulb will last about two years). A bulb can last longer if
it's used less frequently. Typically, a bulb in a DLP TV for household
use should last at least three to four years before it starts to flicker
and needs to be replaced.
there is not true schmatic to change a Dlp bulb. It should slide or twist right out of its balast and you should be able to put a new one in the same way.
