Well, you know you can just buy one right? Try the links below:
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
the unit will only **** up solution when the pressure is low, thats how they all work so you cant use pressure at the same time. You will notice that the pressure drops when using the solution ****..
soap 1st the pressure wash.
I had the same problem on the same unit. All you need to do is pull out the front tip of the gun nozzle to engage the soap dispenser. It's as simple as that, but because there is only a tiny footprint mention of this in the instructions, it turns out to be a long drawn out problem for many of us. Hope this helps.
