SOURCE: Princeton VL1919 repeatedly pops when turned on
If you feel confident take the monitor back cover off and replace the 3 bulged out capacitors
SOURCE: Princeton VL173 scrren blank
Sounds like the monitor took a power surge. Monitor is probably bad but try hooking up the power to the monitor on a different power outlet and see if it turns on, if not then the monitor is bad and would need to be replaced.
SOURCE: Princeton Digital VL1716 monitor - no image and completely dark
maybe the fuse in the plug socket, maybe the monitor is knackered, maybe a faulty connection to the monitor the computer lead or power lead, if all listed above fail then chuck it in the bin!!
SOURCE: Problems with Princeton Digital VL2018W Monitor?
Check inside for bad caps, see failed Princeton here: http://s807.photobucket.com/home/budm/allalbums
Common failure for this monitor.
