Question about Mitsubishi VS-80803 TV
Powers itself off after 1 hr of use
My tv just got back from the repair shop for a "no power on" problem. Now, I can watch a movie for about an hour and the screen slowly flashes green until it just "blacks out". My repair guy has given up I believe, any suggestions? Also, when I saw white letters they were shadowed on the right side by red. Any ideas on that?
Posted by daizee on
Larry
  • Mitsubishi Master
  • 2,800 Answers
Has the timing control board been changed?...or is it part of the panel on your set?
Posted on Nov 24, 2017
5 Related Answers
Anonymous
  • 337 Answers
SOURCE: picture faded to black, came back, faded again and had stayed black.
It seems your set has a loose conection in the high voltage circuits,in fact by now it should have many loose conections in different areas like the power supply and the horizontal deflection circuits,if you are familiar with tv service you can use the information as the first step to take,some of the loose conections are hard to see even for the trained technician but the one giving you this problem should not be hard to see,if you are not too familiar with tv service be safe and call for assistance from a servicer a least for an estimate.
Posted on Oct 11, 2006
Anonymous
  • 556 Answers
SOURCE: white horizontal line down middle of TV screen
caution whenever you see horizontal line please reduce brightness of your tv for safety of crt. your problem in vertical section only mostly due to loose contact in connector,print or loose components.
Posted on Sep 21, 2007
Dewayne Turner
  • 87 Answers
SOURCE: Bow like image
You likely have bad convergence output ic's type #STK392-570.  These can be purchased at UED 800-648-6657.  You will need to remove the board they are mounted on to be able to usolder the old ones and resolder the new ones.  These will be mounted on heat sinks.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Posted on Oct 22, 2007
Lashawn Robinson
  • 1153 Answers
SOURCE: tv powers on, then switches off immediately
check out ctechnicians.com and find error codes
Posted on Dec 25, 2007
Vista Electronics
  • 1694 Answers
SOURCE: red and green lamps look off center
Intermittant convergence alignment issues are quite common.
Either solder the convergence IC pins or better yet , change out
the IC's with first quality OEM spec or upgrade..............T.
Posted on Apr 04, 2008
RCA P56950 Powers on then 10 mins later powers off, repeats cycle. Then channel display in TV changes by itself
may be some thing is stuct on the controt pannel power button or others check. try this it may work
Jun 04, 2012 | RCA P56950 56" Rear Projection Television
Unit shuts down while watching it. Unplug power source, replug, will not stay on. It powers up then shuts down. Will come on after power disconnected but lenght of time varies from 1 hour to 48 hrs or...
I have some repaired unit with the same problem as what you've encountered right now.
It is commonly caused by faulty electrolytic capacitor on the low voltage power supply, mostly on the regulator section. Leaky capacitor will affect the performance of the power supply that's why it is hart to power up.
It is not DIY and quite technical so I've advice you to look for a qualified technician or send it to repair shop to isolate the problem. This is fixable.
Thanks for using fixya.
Please rate my help.
Jan 17, 2011 | Sharp 27L-S100 27" TV
Shuts off after about 1 hr and then we have to power off
The TV might be on sleep mode, so it will stay on for an hour, then turn off again. You'll need to turn it off through the menu
Apr 03, 2009 | Hitachi 60SDX88B 60" Rear Projection...
Tv unexpectedly powers off
Hi i has the same probleme..... My tv has 1 years and 6month... since two days.... the tv turn off itself...I have just take 15minute, unplug tv, and i have open in the right side the little panel...And i have clean inside!!! And i have do the same thing with the big panel in the back of the TV...After i have clean the fan...After this clean my tv is number one... and nothing turn off
Apr 21, 2008 | Toshiba 42HM66 42" Projection HDTV
Philips FTR 9964 Receiver Problem
The problem is in your cable connection on the back of your monitor or Box. I had the same problem and solved it by reattaching the VGA cable that was loose.
Nov 14, 2007 | Philips FTR-9964 Tuner/Receiver for Plasma
Tv powers on, then switches off immediately
Oct 07, 2007 | Mitsubishi VS-60607 TV
No picture on LCD
The LCD backlight has died. If it is still under warranty you may want to contact Mintek and see what they can offer you.
Aug 31, 2007 | Mintek DVD-1710 Portable DVD Player
Mitsubishi VS-80803 TV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
