SOURCE: Graco convertible crib/missing parts
Try www.productsamerica.com. They have many crib parts.
SOURCE: Parts List for Graco 3 in 1 crib
Please read this...
About 1 Million Simplicity Cribs Recalled Due To Failures Resulting in Infant Deaths
NOTE: Repair Kits that immobilize the drop-side are now available
ALSO NOTE: Consumers who have participated or have yet to respond to Simplicity’s June 2007 recall of Nursery-in-a-Box cribs are strongly urged to also participate in this recall.
AND ADDITIONALLY: A subsequent recall involving Simplicity drop side cribs has been issued.
WASHINGTON, D.C. - The U.S. Consumer Product Safety Commission (CPSC) is announcing today a voluntary recall with Simplicity Inc., of Reading, Pa., of about 1 million cribs. The drop-side can detach from the crib, which can create a dangerous gap and lead to the entrapment and suffocation of infants. CPSC is aware of two deaths in Simplicity manufactured cribs with older style hardware, including a 9-month-old child and a 6-month-old child, where the drop-side was installed upside down. CPSC is also aware of seven infant entrapments and 55 incidents in these cribs.
CPSC is also investigating the death of a 1-year-old child in a Simplicity crib with newer style hardware, in which the drop-side was installed upside down. CPSC is warning parents and caregivers to check all Simplicity cribs to make sure the drop-side is installed right side up.
The drop-side failures result from both the hardware and crib design, which allow consumers to unintentionally install the drop-side upside down. This, in turn, can weaken the hardware and cause the drop-side to detach from the crib. When the drop-side detaches, it creates a gap in which infants can become entrapped.
CPSC is also aware of two incidents that occurred when the drop-side was correctly installed with older style hardware, though the upside down installation greatly increases the risk of failure.
The recalled Simplicity crib models include: Aspen 3 in 1, Aspen 4 in 1, Nursery-in-a-Box, Crib N Changer Combo, Chelsea and Pooh 4 in 1. The recall also involves the following Simplicity cribs that used the Graco logo: Aspen 3 in 1, Ultra 3 in 1, Ultra 4 in1, Ultra 5 in 1, Whitney and the Trio.
The recalled cribs have one of the following model numbers, which can be found on the envelope attached to the mattress support and on the label attached to the headboard: 4600, 4605, 4705, 5000, 8000, 8324, 8800, 8740, 8910, 8994, 8050, 8750, 8760, and 8996.
The cribs, which were made in China, were sold in department stores, children’s stores and mass merchandisers nationwide from January 1998 through May 2007 for between $100 and $300.
As an immediate precaution, consumers should check to see if the drop-side is installed right side up. To do this, check to see that the slightly rounded rail with the decorative groove is installed at the top and the plain rail is on the bottom. Next, consumers should make sure the drop-side is securely attached to the tracks in all four corners.
Here's the website...
http://www.cpsc.gov/cpscpub/prerel/prhtml07/07307.html
Please be safe.
SOURCE: graco lauren crib conversion instructions
I have posted the instructions in an album on photobucket. I believe you can print them from there. To get to them, go to photobucket.com and in the website only search field (not the web search) type emilykenepp and change the search from images to people. It should bring up my profile and under albums I have an album called Graco Lauren Crib Assembly Instructions. Click on that and you're good to go! Pages 10 and 11 are for conversions. If you have any further need, the number for LaJobi is 1-888-266-2848 and the number for Graco is 1-800-345-4109.
SOURCE: Need Instruction Manual for the Graco Travel Lite Crib
http://www.gracobaby.com/Instruction%20Manuals/ISPP058AE.pdf Here is a link I used to get instructions for mine. Otherwise go to gracobaby.com and go to the Help Center you enter your model # which can be found on the bottom of the crib and you can download the instructions using Adobe.
Hope this helps anyone.
SOURCE: Conversion instructions for the Graco Aspen 3-in-1 crib
I have the instructions still but the crib was recalled
http://www.cpsc.gov/cpscpub/prerel/prhtml09/09260list.html
