It's not suppose to say Refresh Database when you connect it to the
computer, it's only suppose to say that when you eject it OUT of your
computer.
Did you load a massive amount of files during your last sync?
I don't think there's any need in resetting it if it is able to turn
off and on. What I recommend doing is formatting it. Remember,
formatting the player will cause you to loose ALL your media stored in
the device. To format go to "My Computer" > "Sansa e260" right click
and go down to format.
If it formats, then good. Turn it on and it should say "Refresh
Database". Change the mode of your player to MTP(?) so that it will no
longer refresh the database after transferring media(?).
Connect it back to your computer and reload your media onto it that was
wiped out during the format. Now disconnect it and see if it works...
It should.
If that doesn't work this should do the job for you:
http://sandisk.com/Retail/Default.aspx?C...
Always remember to update the firmware on your products, it is a wise idea to do so. (:
http://sandisk.com/Retail/Default.aspx?C... < Get updates with that.
Drain the battery if whatever you do don't work. Sometimes removing the battery for a few seconds on putting it back in works.
If you think you attacked this problem from every angle and still no
luck. Contact sandisk:
[email protected] Give them some time, their
swamped with emails at the moment.
If you have a microSD card installed, remove it. Press and hold the power button for fifteen seconds before releasing it. Does that do anything?
