Convert audio to text - Audio Players & Recorders
Posted by sanrae222 on
ewanson
Currently it's very easy. Just visit this page https://audext.com/ and choose the necessary format of audio which should be converted. I usually use it and it works on all my devices, even iPhone and iPad. 1-hour-audio is transcribing for approximately 10 minutes. Very fastly, I recommend it!
Posted on Jul 10, 2020
natashards
    New Friend:
I think you cant convert audio to text using some softare because their quality was not good .Even i suggest you to try www.transcriptionsservice.com to transcribe your audio to text.Because am using their service and their result was good.
Posted on May 09, 2011
Tip
Free Convert PDF to TEXT
<a></a> <span><span><span><span><span>To help you convert PDF to TEXT free, Here are 3 methods of converting PDF to TEXT for free. See how to:</span></span></span></span></span> <span><span><span><span><span><br /></span></span></span></span></span> <span><span><span><span><span>PDF to TEXT ConverterFreeware: Calibre</span></span></span></span></span> <span><span><span><span><span>Calibre is a </span></span></span></span></span><a href="http://www.drm-remove.com/resource/how-to-convert-pdf-to-text-free.html"><span><span><span><span><span>pdf to text converter</span></span></span></span></span></a><span><span><span><span><span> software which can convertfrom PDF to TEXT free and convert eBooks between almost all popular eBookformats. Following are the input and output formats:</span></span></span></span></span> <span><span><span><span><span>Input Formats: CBZ, CBR, CBC,CHM, EPUB, FB2, HTML, LIT, LRF, MOBI, ODT, PDF, PRC**, PDB, PML, RB, RTF, SNB,TCR, TXT</span></span></span></span></span> <span><span><span><span><span>Output Formats: EPUB, FB2,OEB, LIT, LRF, MOBI, PDB, PML, RB, PDF, SNB, TCR, TXT</span></span></span></span></span> <span><span><span><span><span>Pros: Totally Free</span></span></span></span></span> <span><span><span><span><span>Cons: Cannot extract imagesfrom some PDF files. All tables are also represented as vector diagrams, thusthey cannot be extracted. Doesn't support batch conversion.</span></span></span></span></span> <span><span><span></span></span></span> <span><span><span><span><span>Convert PDF to TEXT withAissesoft for Free</span></span></span></span></span> <span><span><span><span><span>Aiseesoft PDF ConverterUltimate is the 3-in-1 PDF Converter for you to </span></span></span></span></span><a href="http://www.drm-remove.com/resource/converting-pdf-to-word-free.html"><span><span><span><span><span><span>convert from pdf to word</span></span></span></span></span></span></a><span><span><span><span><span> , PDF to .txt and </span></span></span></span></span><a href="http://www.drm-remove.com/resource/convert-pdf-to-dwg-free.html"><span><span><span><span><span><span>convert pdf to dwg</span></span></span></span></span></span></a><span><span><span><span><span> . After the conversion, you can easily enjoy or edit the files. Foryou to get the exact file that you need, you can specify the page(s) that youneed and also you can choose to convert all pages. This PDF Converter isabsolutely the standalone program, then you can directly use it with anyassistant program like Adobe Acrobat or Adobe Reader and so on.</span></span></span></span></span> <span><span><span><span><span>Pros: 3-in-one PDF conversiontool; Easy to use; Fast processing speed; Batch conversion.</span></span></span></span></span> <span><span><span><span><span>Cons: Only free to downloadthe free trial version.</span></span></span></span></span> <span><span><span></span></span></span> <span><span><span><span><span>Convert PDF to TEXT Online forFree</span></span></span></span></span> <span><span><span><span><span>Zamzar provides free onlinefile conversion, including converting PDF to TEXT. What you need do is toupload your PDF files, select TEXT as the output format, enter the emailaddress and then click "Convert" to convert PDF to TEXT online forfree.</span></span></span></span></span> <span><span><span><span><span>Pros: Totally free, no needany PDF to TEXT converters.</span></span></span></span></span> <span><span><span><span><span>Cons: Doesn't support batch conversion;Can't extract images and tablets.</span></span></span></span></span> <span><span><span></span></span></span> <span><span><span><span><span>Tip: If your PDF files areprotected by DRM, you can use </span></span></span></span></span><a href="http://www.drm-remove.com/"><span><span><span><span><span><span>drm removal</span></span></span></span></span></span></a><span><span><span><span><span> to remove DRM from PDF.</span></span></span></span></span>
on Aug 04, 2011 | Computers & Internet
How do I open a PDF file on my Coby MP-707?
You will need to convert the PDF to a txt file to open the file on the Coby MP-707. You can carry it on the MP3 player to open with a computer with Adobe Reader or any Office Suite that handles pdf conversion. For example, Open Office will import pdf files if you add the pdf extension - the pdf will end up in Draw, IIRC.
I do not know how well the PDF to txt converters work. Here is one program, http://www.pdfzilla.com/zilla_pdf_to_txt_converter.html, that doesn't require you to upload the file to the internet first. Additional options can be found by google: enter PDF to TXT conversion.
This MP3 player can read MP3, WMA, MPG, VOB, MP4, AVI, FLV, WMV, JPG and TXT files. The Coby Media Manager included on the MP3 only player converts audio and video files.
I hope this helps.
Nov 20, 2010 | Coby MP707 MP3 Player
I want to set a video as a tone when i get a text message
Its really not usual in market with mobile phones playing video instead of just audio when you receive a text or a call. Currently you only have the option of audio, so if you can compromise your video on the very related audio of its, then all you need is a video to audio conversion tool, and your job is pretty most done! Every machine has its own audio supporting constraint. It could be an mp3 format or a midi. So you need to convert it accordingly and dump it into your phone and set it default.
Jun 27, 2010 | Samsung Rant Cell Phone
CONVERSION OF NUMERICAL VALUE INTO TEXT IN M.S. EXCEL
to convert numbers into text, just add an apostrophe ' to the left of the number. When you press enter, the apostrophe will no appear, but the number will have the atrtibutes of text
Nov 18, 2008 | Microsoft Windows XP Home Edition
Training my audio recorder to my voice in order to convert sound to text
buen dia, necesito el motor de reconocimiento de voz en español para mi grabadora, ya que no puedo usar la funcion de sonido a texto
Apr 17, 2008 | Panasonic RR-US395 Digital Voice Recorder
37 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
