Question about Precor EFX 546i Elliptical Version 4
Precor Error 45, Lift Moving in Wrong Direction
Probable Cause
1. Lift motor hysteresis.
2. Lower PCA is bad.
Corrective Action
1. The error would usually occur when the lift was already in motion (usually downward) when a lift command in the opposite direction (upward) was made. Some lift motors used in production exhibited a very long turnaround time and the lift motor would still be moving in the original commanded direction while the control system was trying to move the lift in the opposite commanded direction. If the error continues to re-occur, replace the lift motor.
2. It is a rare condition, however if the lift moves in the opposite direction commanded, replace the lower PCA.
Precor Error Code 45
Posted on May 15, 2014
SOURCE: i pulled the plug on my precor efx and now it wont
yes, we can help. 281-469-8506 www.nashsfitness.com
Posted on Aug 10, 2009
SOURCE: looking for repair manuals and error codes for
Could you please advice about ERROR 29 fo C956i/C966i treadmill.
Posted on Mar 04, 2010
SOURCE: belt replacement for precor efx 645 verison 1
You may have to purchase the belt from a Precor dealer in you area, if you don't have one then call Precor directly @ 1-800-347-4404 and they will help you. Most of these part have not hit the secondary market yet and Precor pretty much call the shots.
Posted on Mar 13, 2010
SOURCE: i am looking for a parts and repair manual for a
Go to National Gym Supply @ gymparts.com or call them @ 1-800-496-7278
Posted on Jul 29, 2010
SOURCE: I get an error message on my Precor EFX5.17
Error 54 - Target Pulses Lost During Operation...
Description...
This error is associated with the 5.17 EFX. This error indicates that at some time after the initial start up sequence was successfully completed, the gear motor was instructed to move and no response was seen from the motors revolution sensor.
Possible Causes
(1.) The F2 fuse is blown....
(2.) Damaged or Intermittent gear motor wiring....
(3.) Bad gear motor....
(4.) Damaged gear motor target...
(5.) Bad lower PCA....
Possible Remedies....
(1.) Remove power from the 5.17. Remove the F2 fuse from the lower PCA. Measure the fuse with an ohmmeter. The fuse should measure 1 ohm or less. If the reading is significantly high, replace the fuse. If the F2 fuse was blown there may have been a reason that will cause the fuse to blow again such as; damaged gear motor wiring or a bad gear motor.....
(2.) Carefully inspect the gear motor wiring for intermittent or damaged wiring or connections. Replace or repair the wiring or connections as appropriate.....
(3.) With power removed from the 5.17, remove both wires from the gear motor. Measure the gear motor resistance with an ohmmeter, it should read approximately 9 ohms. If the reading
is significantly low or significantly high, replace the gear motor.....
(4.) Visually inspect the gear motor target, if it is ripped, torn or badly scratched, replace the target.....
(5.) Measure the voltage at the gear motor during the start up sequence, it should measure approximately 12 V.D.C. The voltage would only be present between the time the sequence
was initiated and an error was displayed.. If the voltage is significantly low or absent and the F2 fuse is good (see step 1), replace the lower PCA......
Hope this has helped you....
Thanks...
Posted on Sep 08, 2010
Oct 02, 2014 | Precor EFX 546i Elliptical Version 4
Feb 03, 2014 | Precor EFX 546i Elliptical Version 4
Nov 22, 2012 | Precor EFX 546i Elliptical Version 4
Nov 11, 2012 | Precor EFX 546i Elliptical Version 4
Aug 05, 2011 | Precor EFX 546i Elliptical Version 4
Nov 20, 2010 | Precor EFX 546i Elliptical Version 4
Jul 27, 2010 | Precor EFX 546i Elliptical Version 4
Jul 19, 2009 | Precor EFX 546i Elliptical Version 4
Jun 27, 2009 | Precor EFX 546i Elliptical Version 4
216 people viewed this question
